Toffee delights
Lister79
Toffee delights
Post by Lister79 »
Upgraded the door and dash speakers to some Addison APK165. Used the original dash speakers so I can retain the original speaker connectors. Also removed the original Audison badges from the supplied speaker grills and added them to the door panels.
brooneye
Re: Toffee delights
Post by brooneye »
Another good job and those look at cracking bit of kit
tonyhill
Re: Toffee delights
Post by tonyhill »
Neat 👍
Lister79
Re: Toffee delights
Post by Lister79 »
Thanks lads. Yeah great speakers @brooneye, I think I’ll have to add an amp now to get the most out of them.
Grifnut
Re: Toffee delights
Post by Grifnut »
Great idea on the Audison badges really nice touch
Caddy46
Re: Toffee delights
Post by Caddy46 »
Just read from start to finish bloody amazing work on the caddy attention to detail or what! Couldn’t find any info on the wheels they look mint! 👌🏻
Lister79
Re: Toffee delights
Post by Lister79 »
Cheers mate.
Filip Deleu
Re: Toffee delights
Post by Filip Deleu »
Damn!! Your build looks stunning mate! :shock:
Lister79
Re: Toffee delights
Post by Lister79 »
Thanks very much.
Filip Deleu
Re: Toffee delights
Did you need any extra modules for your puddle lights and touran mirrors? Or was everything just coding?
And I just got some Arteon R-Line seats myself and going to buy Touran bases for the storage underneath. They’re heated seats and drivers seat is partial electronic. I know I will have to add looming and another panel. But I was wondering. Your new panel you recently installed. I saw that you also got a new heater box. Is that to make the dual part work? And I’m also wondering about your connections to the panel. Because I’m looking at a golf 6 panel but those connections are different from the one that’s OEM in my Caddy.
Reason: removed quote
Lister79
Toffee delights
Post by Lister79 »
Hi mate, the puddle lights and mirrors only required coding, but mine aren’t powerfold (you will need modules if fitting powerfold ones).
For the front seat heating if you contact either @stan the man or @tommyzoom on here, they will be able to make you a full loom to get your seats working as per factory.
Yeah I fit the full heater box for the dual zone. The heater box loom replaces two or the connectors at the control panel then you have to reassign the pins in the connector from the van loom and add additional wiring for the new sensors.
If you have a look at the post in the technical section (link above) there are some wiring diagrams to give you an idea of what’s needed, I hope that helps.
Filip Deleu
Re: Toffee delights
I would probably go all in with the mirrors and get the full option ones. As they only cost a little bit more.
Yes if the seats would work like OEM that would be great! Except for the airbags. Don’t really fancy to get those to work. As the drivers airbag already blew up and the seat had to be restitched. Only passenger side would work but not to keen on blowing that one up in worst case scenario lol.
Only joined this forum yesterday. Been active on the Facebook groups since a while. Now wanted to join this forum and see all the things people are working on 🙂
Cheers mate! Thanks for your info! Can’t wait to see more progress of your awesome van!
Lister79
Toffee delights
Post by Lister79 »
The new heater/radio facia arrived to the dealer today. Collected it and then modified it slightly to incorporate the Satin chrome trim from a MK7 golf.
Original look
MK7 Golf trim
Test fit in the new trim
Trim wrapped ready to install
Jeffers76
Re: Toffee delights
Post by Jeffers76 »
That looks awesome so want this
Re: Toffee delights
Looks wicked.
Great finishing touch to the climate panel and if you weren't told you'd think it was supposed to be there.
