Toffee delights
Re: Toffee delights
Lovely, again!
- R22LRM
Re: Toffee delights
StunningLister79 wrote:Very minor update. Collected my genuine bottle opener today to complete my centre console, also added some tartan inside.
Hopefully Optimus Automotive trimmers will be opening this week, so I’ll be able to get my dash and cards sent off soon to have the tops trimmed in leather, then I can get it all put back together.
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
Danlong10
Re: Toffee delights
Did these require coding for them to work?Lister79 wrote:Got the headlights down from the loft today, they have sat in that box for far too long now.
- Lister79
Re: Toffee delights
Thanks lads.
@Danlong10. No they are plug and play, but obviously custom built for the van.
- Lister79
Toffee delights
Well I wasn’t going to bother with a premium cluster because if all goes well I’ll have to replace the cluster in the future anyway. But when a set of Touran ones came up for a real good price I just could let them pass. I know they aren’t the 3D versions but they still look pretty cool. Thanks to Nikki @twinsport for doing the immo, coding and tank data changes.
Speedo/fuel gauge foil also swapped over to keep fuel filler symbol correct and my OCD in check
One thing I have noticed is that these don’t show the service due data or have the Tyre pressure store option for the TPMS. Hopefully this can be rectified with a software update otherwise I’ll have to refit the originals.
Fitted
Before
*bulb warning on due to not currently having the front fog lights connected.
.One thing I have noticed is that these don’t show the service due data or have the Tyre pressure store option for the TPMS. Hopefully this can be rectified with a software update otherwise I’ll have to refit the originals.
Fitted
Before
Anton
Re: Toffee delights
Nice little mod this pal, hope you can get it all set up and sorted how you want
- Lister79
Re: Toffee delights
Yeah I do like them, could always revert the coding back to remove the TPMS.. I’ll see what happens.
Re: Toffee delights
They look lovely.....but so did the others!
Top work, as always......
- Lister79
Re: Toffee delights
Picked up some Satin chrome door handles and mirror switch today so swapped over the light diffusers ready for when I get my door cards and dash back.
- Beaker2135
Re: Toffee delights
Nice one, it is supposed to be my next job but I must have had the bits getting on for a year
You can’t rush a good job
Re: Toffee delights
Really like these Chris....did you put the part numbers up anywhere?
- Lister79
Re: Toffee delights
your right there Steve, good things come to those who wait....Haven’t had time to go through the useful numbers thread yet Pat (to make sure I’m not duplicating), hopefully do it tomorrow.
Part numbers are:
Mirror switch - 1T2959552H
Passenger side - 1T2837113CUBN
Drivers side - 1T2837114DUBN
Re: Toffee delights
Thanks chap
- Lister79
Toffee delights
Finally finished my additional cluster housing tonight, more hours than I care to think of have went into this (this is mod D). Top half is original Scirocco and the lower section is completely manufactured/bodged/moulded/knocked up (or whatever other term you want to use.
Can’t try it in the dash as it’s still away so I’m hoping it won’t look “stuck on” otherwise it will have been a big waste of time. If it does look right I think I’ll end up getting it trimmed in leather to match the dash but I’ll see once I get it in.
Still need to make the final loom up which I’ll do at the weekend but everything worked on the trial wire up. Just need some boost now......
In work (no particular order)
- Azz03
Re: Toffee delights
Lister79 smashed it again with both the new mods mate seems there’s nothing you can’t think of haha. Just a question what’s the additional clocks for?
