ToiletTFSI
Re: Let the build begin continues with VR6 heart transplant
Post by ToiletTFSI »
Great work, mounting the box through the floor with the spare usually sits?
ktmpedro220
Post by ktmpedro220 »
Wow. Fair play to you.
C Chis
Post by C Chis »
[mention]ToiletTFSI [/mention] yeah, made the box small enough to fit between the rear crash bar and the last cross brace.
[mention]ktmpedro220 [/mention] cheers buddy, work in progress…
C Chis
Post by C Chis »
No zip ties were harmed in the installation of the suspension
C Chis
Post by C Chis »
Not a big update however…
Control panel fabricated, painted and the components mounted.
Ps… just because it’s hidden doesn’t mean you take shortcuts and leave it untidy Image
And I cut and installed some fine st. st. mesh into the compressor box vents to reduce the likelihood of water ingress.
Very nice 👌
It's the little details that make all the difference
C Chis
Post by C Chis »
Yeah, gives you that warm glow of knowing
C Chis
Let the build begin - VR6 and air on the way!
Post by C Chis »
Little bit of progress over the last couple of days…
Lifted the ply to find it was screwed through the metal floor! Grrrr…
Screw heads were all corroded… gentle persuasion required.
No going back now! Marked up the cut, 5 minutes later, compressor box shaped hole in the floor. Slightly off centre to allow the box to fit without having to cut into the cross member and to avoid the rear silencer box mount.
Box in for a test fit
Test fit of the air tank too. Need to slide it over to the left a little more. Also, I’ll need to order up a replacement heat shield for the silencer.
Box welded in, gravitex’d, stone chipped and colour matched to the inside of the van. Dual competition Grinds compressors with automatic water drain valves also installed.
Hopefully I’ll have everything wired up tested this weekend ahead of welding on the Retrofication leaf spring saddles and APB/Bilstein suspension.
Oh, and the seam sealer nozzle blew off when sealing the inside so I’m not 100% happy with the less than perfect, kinda rough finish so will most likely redo it in a few weeks time when the spare parts arrive, however, sealed and protected for now.
Lister79
Re: Let the build begin - VR6 and air on the way!
Post by Lister79 »
Looking good.
Torgeirl
Post by Torgeirl »
slide rail looks so much better. thinking of getting one myself.
Reason: Quote removed
Torgeirl
Post by Torgeirl »
C Chis wrote: Sat Jan 09, 2021 3:47 pm New rear lights fitted and coded in using the rather good how to guide in the “how to” section! Many thanks to Doc for writing it up and sharing
Just got a pair of these taillights today. And it looks so much better than pre facelift. :D
Reason: Photos removed from quote.
Dixuk
Post by Dixuk »
Hi chris hell ive looked through your build good read how long have you been at it mate fair play 👍
C Chis
Post by C Chis »
[mention]Dixuk [/mention] thanks for taking the time to have a read through! It’s only been 31 months!
31 months of fun 😎
C Chis
Post by C Chis »
[mention]petrev [/mention]
Definitely! Kept me busy during the lockdowns!
