Went to Hazzy Dayz today to get the genuine VW xenons fitted and coded. They did a great job and were friendly and informative. Ok, so they're not cheap but I would recommend them.
I left the van with them for 4 hours and thought I'd kill some time in Luton. Got a cab back after lunch and then got into my first traffic accident where the airbags went off. A guy who had pulled into a side road to turn around just kept swinging round until he had pulled straight out of the junction into our path.
Luckily the taxi driver got on the brakes and although we skidded, definitely slowed us down. We ploughed into the side of the '12 plate Focus doing a smidge under 30 I reckon. Both our airbags deployed - this is not a pleasant experience as its similar to a shotgun going off inside the car, but as I had my seatbelt on my face didn't hit the bag.
I jumped out and checked the other car. The guy was bit shell shocked but he was lucky it was a new car with curtain airbags, otherwise we might have been calling for emergency crews to cut him out.
The Focus is a write off. The impact has bent the chassis I reckon. We hit it square on across the drivers door and the front wing
No one suffered any obvious injuries but my neck is beginning to feel a little stiff. We had a few seconds to brace for the impact which probably helped.
This is the aftermath
These are the new lights fitted. I've got to get the AFS and levelling module done afterall as the full beam isn't done using a shutter on these ones, its controlled through the levelling/cornering module
These are the LED DRLs which can be turned on and off through the MFD lighting menu. They are also the sidelights.
and the xenons. Think they're a bit low at the moment but obviously once get the levelling system fitted they will be fine.
