C Chis
Re: Let the build begin - Plushed VR6
Post by C Chis »
Looking to rub it down, treat the rust, etch prime and spray it India blue or perhaps finish with black gravitex, not sure yet.
Skulirag
Post by Skulirag »
Thing looks sick!
Where are the secondary rubber seals from ?
C Chis
Post by C Chis »
Hiya, cheers!
I bought one from eBay a while back the other was from LLL parts, both genuine VW Caddy door seals.
Cuts out a little noise but makes the doors sound so nice when closing!
C Chis
Post by C Chis »
Touran xenon headlights fitted this morning, straight forward enough. Halfway house for now (manual level adjustment) until I’ve tried them for a bit.
Need to get rid of the moisture with some silica gel sachets to get rid of the moisture, downside of long term storage and fitting them on a cold, wet drizzly day Image
Halfway house : removed the Touran stepper motors and replaced them with the original Caddy headlight height adjustment motors. Holding off on fitting the front and rear level sensors and the control module for automatic levelling until I’ve run them for a bit to make sure I’m happy with them.
Original stepper motor on the way out
Caddy motor installed with the original fittings, you’ve got to love VW for their multi use parts!
Additional wires run from the CECM to headlights to operate the Shutters for main beam, coding ticked and most importantly, no warning light on the instrument cluster and no flickering!
Going to swap out the H7 halogen lamps in a few weeks to try and match the colour temperature to the xenon’s.
Then… automatic levelling and headlight washers!
Exterior6357
Re: Let the build begin - Plushed/Bagged VR6
Post by Exterior6357 »
Brilliant thread! Love a VR6, how does the caddy feel on full power? Sketchy or still planted enough?
mando
Post by mando »
C Chis wrote:A quick picture at dusk, I’ll take some better ones over the weekend after I’ve cleaned the carpets, covered in muck and straw at the moment Image
Hi mate, what are the 2 fixings where the old light was? Are they just caps?
C Chis
Post by C Chis »
Exterior6357 wrote:Brilliant thread! Love a VR6, how does the caddy feel on full power? Sketchy or still planted enough?
Cheers! Thanks for taking the time to have a read through.
Planted when it’s dry, very, very sketchy from a standing start when it’s wet! ImageImage
C Chis
Post by C Chis »
[mention]mando [/mention]
Hi buddy, yes, just caps. The holes give access to the original fixing points for the shelf
Slammedwhitecaddy
Post by Slammedwhitecaddy »
Hi mate any chance you know what wires go to what on the rep in of the 4 button to 2 button switches
C Chis
Post by C Chis »
Yes, however it all depends on the year of your van, door module, etc…
There will also be details in the how to part of the forum, best to get your post count up and request an upgrade and check in there.
C Chis
Post by C Chis »
So, it’s been a while…
Finally took the plunge and upgraded from my premium colour display to a digital display, straight forward job, old one out, stripped down to the pcb, installed into the back of the digital display with a very slight modification to the back right hand side of the dash cowling (to clear a small part of the new case).
Good fit in the Touran dash, no gaps, no issues setting up
Loving it!
Oh, and the warning lights were separate issues, now all sorted apart from the seat belt warning, this is new since upgrading to the digital cluster. I’ll sort that one out by wiring in the seatbelt switches.
Alex mc
Post by Alex mc »
Hi Colin the clocks look awesome do they make a diesel version of these .
C Chis
Post by C Chis »
Hi Alex, yes, I believe so. I went from a diesel cluster to this one.
PM me if you want to see the dash in person and we can sort something out
gogsie
Post by gogsie »
Alex mc wrote: Sun Feb 09, 2025 9:02 pm Hi Colin the clocks look awesome do they make a diesel version of these .
I have these in my mk4 caddy and you can change the clocks to diesel rev/mph range in the settings.
Nathangroom21
Post by Nathangroom21 »
Hello Chris I Have been following your build for a very long time and finaly took the leap to Vr6 Engine swaping my Caddy.
I am Stuck Stuck on the wiring I was woundering if you could help me out THe Vr6 Engine code is BDB from a A3 with DSG Going into my 2011 Caddy Maxi Cayd.
I have made two exel documents on both wiring pinouts Could you help me get the ignition switch working I know your very good at what u do.
