Made some progress with the sliding door changes.
I need to replace the exterior sliding door handle after pulling it off
I was hoping I could just replace the handle from the outside, however it looks like it won’t be as straight forward as I might need to remove the central locking mechanism from the inside first so I can get access to the handle mechanism.
I also trial fitted the interior trim panel I got from a used caddy life, it should look better once I’ve painted/trimmed it.
I will probably use the carpeted ply panel I had for the top half of the door and cut it to suit the new lower trim.
