Sarbs mk4. dsg conversion✅️
Sabbunsingh
Re: Sarbs new caddy
Post by Sabbunsingh »
IainH91 wrote:Good build!
Early in your build the footwell lights. White with the door and red while driving. I assume these are wired to the light switch:
White to blue/grey wire
Red to the dipped light wire (whatever Colour that is)
Thanks.
They are wired to the bcm.
When does this ever stop!!
Sabbunsingh
Re: Sarbs new caddy
Sag1 wrote:Look absolutely stunning Sarb
Thanks mate
IainH91
Re: Sarbs new caddy
Post by IainH91 »
Ok, do you have the PIN numbers or general details please?
Sabbunsingh
Re: Sarbs new caddy
IainH91 wrote:Ok, do you have the PIN numbers or general details please?
https://www.caddy2k.com/forum/viewtopic ... 15#p315115
I used this thread to find the correct outputs.
DW2KN
Re: Sarbs new caddy
Post by DW2KN »
Really cool build thread, 2 questions. Nust doing my interior now. Where was the caddy life dash trim sourced from and how was it fitted? The gti pedals? Easy fit?
Cheers man
Sent from my SM-N975F using Tapatalk
Sabbunsingh
Re: Sarbs new caddy
DW2KN wrote:Really cool build thread, 2 questions. Nust doing my interior now. Where was the caddy life dash trim sourced from and how was it fitted? The gti pedals? Easy fit?
Cheers man
Trims from tps and replace the standard vents.
Gti pedals clip straight in aswell, they were from a breaker.
DW2KN
Re: Sarbs new caddy
Post by DW2KN »
Thankyou, appreciate the advice
IainH91
Re: Sarbs new caddy
Post by IainH91 »
Sabbunsingh wrote: Tue Jan 05, 2021 10:06 pm https://www.caddy2k.com/forum/viewtopic ... 15#p315115
Thank you, i saw this last night when googling!
Just might be a stupid question. I assume you are just pinning into the correct pin in the connector that lines up to the BCM. This would be empty as you dont have it standard.
Sabbunsingh
Re: Sarbs new caddy
These lights really are the dogs dangly bits.
The 35w d3s works really well.
They also look really cool Image well.ImageImageImage
Sabbunsingh
Re: Sarbs new caddy
Vw are cheap and it annoys me that they didn't fit a screnwash level sensor. I have run out a few times and it can be dangerous on the motorway esp in winter months. I went to a breakers and managed to get the bits to make up a retrofit. Here are a few pics of my loom and a quick test in my shed. ImageImageImageImage
Sabbunsingh
Re: Sarbs new caddy
I came across these genuine vw logo lights on a forum. Found a set on amazon prime for a reasonable price so decided to have a go at fitting them into the caddy door card. The caddy doesn't have a factory hole so I had to cut and glue these in. I made a small loom and coded the door modules to work as per factory. Happy with the look and they are oemImageImageImageImageImage
Sverigr1234
Re: Sarbs new caddy
Post by Sverigr1234 »
Nice :D
Sabbunsingh
Re: Sarbs new caddy
Today's task was to get my screenwash level sensor fitted. Pulled the loom through the bulkhead and tidied loads of wires up from my previous retrofits. Dropped the tank and drilled a 25mm hole, cleaned it all out and fitted the sensor. I them filled the tank and tested for leaks. It was all good so re fitted it all.
I then activated the function in the cluster and while I had the vagcom out I coded my fogs as leaving/coming home lights. Also changed my alarm beep to the quite setting.
Sabbunsingh
Re: Sarbs new caddy
More pics because I can. Sorry not sorryImageImageImage
Re: Sarbs new caddy
Great work on this van dude, you have it looking great.
