Poffe
Re: Caddy Maxi - daily and camper build
Post by Poffe »
Might have been my single scariest job so far. Fixing the rust at the end of the guide rails. And, while at it, fix some dings and dents.
Not a proper paint booth, but close enough for me to take on the job. Came out okay. Will need a proper sanding of the clear coat for sure.
But I will let it harden before touching it with the sander.
Sent from my Nokia 3310
Poffe
Post by Poffe »
Got around to fit the freshly painted side rail covers, colour coded door handles and life side wing mirrors. Really nice to finally see the result of the hard work.
I also had the side trim colour coded. But with all this other parts painted on the side, I’m starting to question my decision.
Poffe
Post by Poffe »
The inside of the van is still a work in progress. Yesterday I had the plywood panel on the insides of the van covered with the foam backed suede. Starting to actually look comfy.Image
Mj_jonesy
Post by Mj_jonesy »
Nice to see a different colour choice for once, rather then ex British Gas or silver….
Poffe
Post by Poffe »
Mj_jonesy wrote: Thu Jan 02, 2025 9:34 am Nice to see a different colour choice for once, rather then ex British Gas or silver….
Well, I can’t really take credit for choosing red from factory. To be honest, I probably would have chosen another colour. But, I m also pleased to not have a white basic paint like every other work van or low spec car has here in Sweden :)
Jobi1
Post by Jobi1 »
Great work so far!
Would you mind telling me what products you have used for all the sound deadening and insulation that you've done so far, and if you have noticed much difference while driving?
I still have some work to do on mine and was going to use mass loaded vinyl for the floors, but not many seem to be using that, so just trying to see what has worked well for others.
Thanks 👍🏻
CaddyMountain
Post by CaddyMountain »
Looks great, upholstering is a big gamechanger in the looks and feeling when you are driving!
Poffe
Post by Poffe »
CaddyMountain wrote: Fri Jan 03, 2025 4:41 pm Looks great, upholstering is a big gamechanger in the looks and feeling when you are driving!
Thank you! I can just agree with you. Feels like a different car by now. And there is still som upholstering to do.
Maxiboi
Post by Maxiboi »
Poffe wrote: Mon Jul 01, 2024 2:27 pm Stripped the interior from all trim mounted above the dash. Put 2mm Silent Coat on all single metal sheets and 10mm Edpm closed cell foam on all surfaces.
I even got the misses to do some work.Image
Loving this build thread! Quick question on this - did you manage to get 10mm foam in the a pillers too with the plastic trim still fitting?
Caddy maxi 2014
Poffe
Post by Poffe »
Maxiboi wrote: Sat Jan 04, 2025 11:16 pm Loving this build thread! Quick question on this - did you manage to get 10mm foam in the a pillers too with the plastic trim still fitting?
Thank you Maxiboi! Yes, the A-pillar trim still fits with issues. Seems like they have a pretty decent amount of space between the body and trim all over. Even have the 10 foam behind the B-pillar trim
Poffe
Post by Poffe »
Jobi1 wrote: Fri Jan 03, 2025 10:00 am Great work so far!
Thanks 👍🏻
Thank you Jobi1!
Of course! Im happy to share what Ive used so far!
Directly agains the body, where there has been a single metal sheet I've used first 2mm SilentCoat sheets (2mm butyl, self adhesive and aluminium top layer). Made a world of difference in the doors, flooring and wheel houses. I even used it on the roof and sides of the cargo area. I completely covered all the single panels with it.
https://www.silentcoat.co.uk/collection ... dening-mat
The I used 10mm EPDM (closed cell foam rubber). Ordered from AliExpress.
This I have covered the areas where the space is a little more limited, like in the cabin doors, flooring (both in the cargo area, but also under the mats in the cabin), A-pillars, Cabin roof etc.
https://www.aliexpress.com/item/1005005 ... 1802PODAK9
For the sliding doors, the cargo roof area, side panels in the cargo space and the rear tail gate i used polyester insulation, made from recycled polyester. Might have choosen a little bit too thick material. Had to half the thinkness at some areas to make it fit.
https://www.amazon.se/-/en/Transporter- ... rp_crs_0_t
Then covered it with bubble foil fastened with aluminium tape.
https://www.biltema.se/fritid/friluftsl ... k0QAvD_BwE
Poffe
Post by Poffe »
A-Pillars reupholstered and mounted!
Might have been the worst parts so far to reupholster. Had to redo one of them after almost completing it. And removing it wasn’t the most fun I’ve had in my life.
Now the colour of the dash and door cards seems a little bit of. Might need to source some nice dash and door cards from a Touran!
Danyell
Post by Danyell »
This looks great! I'm about to start mine, well after the leaf springs been fixed 🤞
It has plastic insulation in it instead of wool under carpeted panels, to avoid mold I've been told.
Ryan3633
Post by Ryan3633 »
The blacked out plastics and trim look a lot more modern, it’s a job I want to do in mine as the standard colour trim looks really old fashioned to me, your caddy’s looking great so far
Maxiboi
Post by Maxiboi »
Poffe wrote: Tue Jan 07, 2025 7:21 am Thank you Maxiboi! Yes, the A-pillar trim still fits with issues. Seems like they have a pretty decent amount of space between the body and trim all over. Even have the 10 foam behind the B-pillar trim
What a win, thanks for that, it’s definitely on my list! I look forward to your updates!
Caddy maxi 2014
