Caddy R360 build thread
- limevehicles
Re: Caddy R360 build thread
new to the forum, simply stunning build!!!
Unit A2 Penygroes Ind. Estate, Penygroes, Caernarfon, Gwynedd. LL54 6DB
Tel : 01286 479 058 Mob :07789008818 Email :limevehicles@hotmail.com
Facebook :https://www.facebook.com/prof ... 5155909287
I've only just seen this post as I'm new to the forum, and the world of caddy's. That is a truly amazing build, I congratulate you sir!
I know that you fitted the air vents a long time ago but did you fit anything to take up the gap between the new air vents and the existing duct work - thanks
- dan@biali
Essentially I made a round to square adapter using some square gutter and a piece of plastic. It looks like this:
- ed1119
Can't wait to see the latest update! I hope you get a chance to bring it over to Dubshed (in NI) in April
- Mindak
That is a beast of a cake!
- dan@biali
I would love to be able to do dubshed but think its more likely to be Early Edition in May thats more realistic.
- ed1119
Seriously...it has to be bothdan@biali wrote:I would love to be able to do dubshed but think its more likely to be Early Edition in May thats more realistic.
- dan@biali
Well it's still in pieces and they haven't started the trimming yet so highly doubt everything that needs to be done before a show will happen in that time!
- ed1119
Good luck with the build I would just love to see it in persondan@biali wrote:Well it's still in pieces and they haven't started the trimming yet so highly doubt everything that needs to be done before a show will happen in that time!
Thanks for the advice on the air vents - didn't think of an adaptor but it makes perfect sense square hole to round hole - how did you hold them in position ?
Slightly off topic your front brakes are off a R32 are you able to cross reference that with ones from an Audi B5-7/S4 to see if these would fit (disc size 345mm)
Thanks again
Thanks again
- dan@biali
I decided that in order for them to work I would bond them in place. I've used a structural adhesive and think it's holding up ok. Can't remember if I squirted in a bit of surface modifier before but wouldn't hurt as dash is made from an oily plastic like polypropylene.
Front brakes are from a MK6 Golf R. No idea if B5-7 is the same. You would need to make sure the bell housing doesn't change the offset needed to clear - for example, I think the ttrs and rs3 discs are same size but different bells and so the rs3 disc won't work on the caddy.
Hi Dan brilliant build. Where did you purchase your hpa manifold if you don't mind me asking.. they are like rocking horse....
- dan@biali
this build thread is epic!!!!! i have just spent the past hour reading from 1 to page 71 on this mint ride!
you have done so well mate !
looks great
looks great
