I saw someone with their headlights in the oven with no explanation, and wondered why. Thank you for making it clear. They look awesome by the way. Deffo a job for mine. Woodyfoxyjay wrote:Prepping them.........I started to Scotch-Brite the mirror finish on one of them, and then was cleaning the dust off with a rag doused in cellulose thinners, when I noticed the mirroring just wiping off completely..........
So I wiped over the rest of it and bob's your uncle, it's alot less hassle than keying it all.
You just have to be careful not to soak the plastic too much as it does soften the surface of it.
The ribbing shape around the main and dip beam are a pain but with patience you can get it 80% off.
It doesn't need to be perfect, and you can abrade it all finally before painting anyway.
Left them for 15 mins to allow the thinners to dry off, then hit it with plastic primer (grey).
A quick light coat, then left 5 mins to flash-off, and then a good coat all over.
After an hour, I top-coated them with satin black paint - working from the back into the openings for a quick first hit, the ensure the ridges all got painted, and then after a couple of minutes, painted the front sides.
I've swapped to the obligatory Diadem indicator bulbs just to funk-up the look (hardly new idea, but still cool imho).
Now just got to mastic the lenses back on, and we're done.......
Project Caddy TDi.........the search for boost
drw42
Re: Project Caddy TDi.........the search for boost
Springer Mad
Wow, Hats off to you for all the work carried out so far and another engine transplant on the cards. Will follow this with interest.
fxy
very nice pal
fxy
im thinking of putting a BKD in a caddy but its wireing putting me off , who is your guy for virginising the ECU ?
thanks foxy
thanks foxy
- torque777
Wow great work ...take it you have access to broken vehicles to help your build ?
- foxyjay
Lee Metcalf at MOT7 01482 329329.fxy wrote:im thinking of putting a BKD in a caddy but its wireing putting me off , who is your guy for virginising the ECU ?
thanks foxy
Immo delete for my ecu by post.
Turbo Power........
- foxyjay
No mate, I bought a donor car specifically for the engine transplant......saves alot of time and messing trying to find bits you forgot!torque777 wrote:Wow great work ...take it you have access to broken vehicles to help your build ?
Turbo Power........
- foxyjay
The caddy is now up for sale on Caddy Club UK Classifieds on FB....
Turbo Power........
shanky887614
Re: RE: Re: Project Caddy TDi.........the search for boost
foxyjay wrote:
I have all the details on what I did if anyone wants a copy.
I took the decision to cut ecu plug rather than poking pins out of plug and swapping them over so I guess I did a bit more joining and soldering than I really needed to.
Wasnt tricky but depends on your skill level and understanding of modern car wiring and electrics.
Main differences are glow plug controller and vacuum control valve block (n75, etc).
have you still got the details of what you did?
Caddy Rob
foxyjay wrote: ↑Sun Jun 23, 2013 8:45 pm Looks like electric rack is going to be the favoured option, as after doing research it appears caddy turbo is opposite hand to bxe/bxc engine.
[/quote
Am at this stage with my van, was searching for a bracket to hold steering pump as sdi one didn’t fit!
After reading this looks like I’ll be taking the steering off the touran.thought I was nearly finished
