P0600 Serial communication link
Anyone had the same error code?? have traction control light, abs light, and flashing brake warning light on... Mechanic has advised me its an ecu problem. So ecu has been sent of to be tested??
- Euro Technika
Re: P0600 Serial communication link
Which ecu?? P0600 is a communication fault has the CAN wiring from ECU to ABS unit been checked? No point sending away a unit if basics haven't been checked.
Hi, i have this exact problem on my 2009 2.0 sdi. abs light on, traction control light on, eml on and fuel light flashing. throwing up the same P0600 code. did you find the problem??
