What you got or what would you recommend?
What about units with Satnav, would I have to fit antenna?
When it comes to the above I'm useless
eonon. Decent head unit has sat nav built in you just run a cable can be hidden under the dash or out by the window. Built in Bluetooth and usb can link aux change colour of LEDs ect. But slow to boot up and would need a roof mounted aerial as signal isn't the best with screen aerialNo more like 10 it's not instant like vw units. Sat nav takes little longer to load maps but would expect that anyway. This unit is designed for vw so just plug and play only comes with single fakra connection where as caddy has double but you can get a different connector off of the bay. Don't have a mfsw yet but yes it has a control box to link buttons to do whatever you want. plays DVDs too and has a touch screen can also connect a dab box but costs bout £50Joepayne1 wrote:@cadmad by slow boot up are you talking more than 20 seconds here?
Well. There are some "bugs".Jakeypops90 wrote:I've been looking at the Pioneer too Lundberg - looks a really nice fit for the caddy! Are you pleased with how it works?
Brand is ACVFarriercaddy wrote:What fascia adapted is this please?
Can this model be controlled with the Multi function steering wheel and is it a straight swap?Joepayne1 wrote:![]()
(Excuse the dark picture)
Going back a few weeks ago I was in exactly the same position as you.
I recently purchased a JVC KW-V215DBT. 55W X 4 with a built in amp, Bluetooth, DAB, USB and other features. Hasn't got sat Nav built in, but with a cable it will connect to your phone and run the maps app.
Paid £210 which was discounted from £550.
I honestly recommend this, you won't even need to upgrade the speakers in the doors either!
