Is there a live feed in rear of caddy?
Posted: Sat Apr 23, 2016 4:51 pm
by hipringle
I need to keep a second 12v battery charged up when the engine is running (for a small water pump), is there a live I can tap into to give the second battery a small constant charge or do I have to go thru the fuse box or direct to main battery with additional fuse etc, many thanks.
Re: Is there a live feed in rear of caddy?
Posted: Sun Apr 24, 2016 1:12 am
by horace01
I'd run a separate wire from the main battery and also use a split charge relay. That way you wouldn't need to keep the engine running when using the pump.
Saying that perhaps you could use the rear wiper motors live feed.
Sent from my HTC One using Tapatalk
Posted: Sun Apr 24, 2016 7:31 am
by hipringle
Thanks Horace01 I might look into the split charge relay from the starter battery, all the best.
Posted: Mon Apr 25, 2016 9:08 am
by chrismarklacey
Just got one from Ebay, its says its for the T5 but will work on anything, £58 and comes with everything you need plus an inline fuse box so you can just connect your 12v accessories straight onto it.
http://www.ebay.co.uk/itm/VW-T5-Camper- ... 1259391582" onclick="window.open(this.href);return false;
