Hedge
hedge
Hedge
Post by hedge »
Caddy was looking good in the car park (how sad!) so I took a picture!
Car park
Van!
Van!
P050309_16.35 (Copy).JPG (122.18 KiB) Viewed 4254 times
Front wheels pre gti brakes
Front wheel
Front wheel
P060309_15.04 (Copy).JPG (95.37 KiB) Viewed 4254 times
Gurrior
Re: Hedge
Post by Gurrior »
wassssssssssssupppppp hedge ...yr mate caddy d sent me an email saying you would know how to lower the back of a caddy.would apreciate if u could give me any advice dude ... :mad:
hedge
Re: Hedge
Post by hedge »
hey!
The back is leaf spring so you need to flip the axel (turn the axel from being underneath the leaf springs to being on top)
this will give you a 60mm drop straight away, problem is that the brackets to do this (standard ones are too weak) don't seem to exist (loads for the mk1-3 caddys!) so the only option for your caddy is Coil overs with adjustable brackets for the back.
start with v-maxx at around £440ish
to kw coilover £1200 to £1500
Fronts lowers from 0 to around 90mm!
back lowers from 60 to around 90mm!
HTH
Hedge
Re: Hedge
hedge wrote:hey!
HTH
Hedge
KW V1 kit can be had for around £900 I think, been a while since I got a price but it was in or around that.
