Had an 03 plate Audi A3 130 pd with 6 speed box which I sold so I could buy my caddy... just missing that engine and box so much lol... anyone done this conversion to their caddy? Or have a link to a build thread?
Pd engine and 6 speed box conversion?
Robr1972
- Baggedcaddy134
Re: Pd engine and 6 speed box conversion?
hi mate just done one on mine what do you need to know ?? just the box sorry
insta: bagged_caddy
facebook: alex husband
niall2123
I am currently doing this. It is not that difficult but it can take time to figure some of the stuff out.
On the donor engine you will need to modify the block to take the new style crank sensor and trigger wheel (which is part of the rear crank seal). You can use all of the existing Caddy ancillaries/boost pipes/airbox/engine management/etc. but you will need a remap to make the most of the engine.
You could try using the old EDC15 control/wiring (from the donor - Golf 4 platform vehicles) and not have to bother with a custom remap but I'm not sure if the version of CAN is the same and/or if it would talk to the instrument cluster/ABS/ESP/other systems. I would like to try, but I didn't get all of the donor components - I bought my van as a franken-project which I am now trying to sort out
**EDIT: I've just seen that you have a 1.6 CR, so this would be a major undertaking...! Better off to start with a 1.9TDI Caddy if you *really* wanted to do this...
Robr1972
Thanks niall.. yeah I think that's too much for me to do lol, not mechanically but I'd struggle with the electrics side of things..
Do you know if it's possible to fit a 6 speed box to a 1.6 ?
And is yours a 1.6 baggedcaddy?
P44ttf
Can the 1.6 engi e be swapped for a asz 1.9
