MFSW confirming options
totty79
Post by totty79 »
Could anyone confirm if the following is correct please.
MFSW with cruise control buttons cannot be used on a facelift caddy without an aftermarket SWCM.
You can fit a MK 5 MFSW along with the matching airbag.
The MFSW can come from most other VWs, but not a Passat.
If retaining original airbag a new airbag wiring harness is required.
maxx007at
Re: MFSW confirming options
Post by maxx007at »
totty79 wrote:Could anyone confirm if the following is correct please.
Passat CC MSFW (without Cruise Control) can be used though, with the correct SWCM.
Both in the Facelift (not sure which module version) and Pre-Facelift (Needs module version CH)
Tiguan 5N2 (2.0 TSI (CCZD) 4Motion, REMAP 158 KW/211PS)
Ex Caddy 2k (e.o.2004) (1.9 TDI(BJB), REMAP 103KW/145PS) Ravenna Blue
totty79
Post by totty79 »
Thanks, I thought at least one point would be inaccurate.
Sandyson
Post by Sandyson »
In face lift models (to 2015) a polo steering wheel will work without and after market swcm, does require a high line swcm though. To get newer generations of golf wheel space walker can provide a custom swcm. Well this is what I was told by a retro fitting company when I enquired last week.
totty79
Post by totty79 »
Cheers.
I've got a highline swcm and stalks with cruise ready to fit.
spacewalker
Post by spacewalker »
Sandyson wrote: Wed Jan 10, 2018 3:58 pm In face lift models (to 2015) a polo steering wheel will work without and after market swcm, does require a high line swcm though. To get newer generations of golf wheel space walker can provide a custom swcm. Well this is what I was told by a retro fitting company when I enquired last week.
Yes, and NO
you can install POLO MFSW , but if you have external BT module (3C8 , 7p6 etc .... ) scroll phone via MFSW is impossible, because new MFSW sending different command .
Also CCS will not work from that type of MFSW because ECU not coresponding correct
I made custom module for all cars since 2004 , you keep current SWCM, and BT etc , module convert signals to proper, also CCS can be operate from MFSW
https://www.youtube.com/watch?v=JQ8cBbeCOvA&t=9s
totty79
Post by totty79 »
Can this wheel and airbag be used on a 2012 van with a 5KO 953 549 B ?
I prefer it to the MK6 ones I've seen which for me are too sporty for a stock van.Image
Sent from my SM-G900F using Tapatalk
Yes, is you're buying the wheel and airbag together they'll be fine paired with that SWCM.
totty79
Post by totty79 »
Thanks Doc, just bought it.
SteveKelly
Post by SteveKelly »
Totty - I’ve had a read through your posts re your mfsw upgrade and your van plans. Did you get a steering wheel with paddles and if so what do you think of them? I’m thinking of this upgrade for my caddy maxi life and am wondering what it offer to life with dsg.
Many thanks
Steve
totty79
Post by totty79 »
Yes, mk5 golf. I find the 'box gets it right itself most of the time so I don't use them much.
They're nice to have when you fancy throwing it around on a good B road, or on tight single track roads where the 'box shifts excessively. No different to using manual on the stick really just more entertaining.
SteveKelly
Thanks for that - I’m not sure I can justify a couple of hundred+ for the wheel. I may just stick with what I have and get a cruise stalk as that seems the most useful for the cash.
eddyrey619
Post by eddyrey619 »
Hello All
I also would like to attempt this projected one day, so i am trying to gathering as much information as possible so please go easy on me :D
i have a 2011 TDI250 2KN SWB caddy and i also want to put a MFSW
Besides the actual steering wheel and the coding behind it all what are the actual things needed to make this work
kinda regards
totty79
Post by totty79 »
SWCM (Steering Wheel Control Module), airbag, airbag loom.
I can see you've hit 6 posts, apply for full forum access and you'll find loads more info.
eddyrey619
thank you totty 79
