Stormtrooper caddy 4 build
- mark1a
Re: Blue obsession caddy 4 build
Quick question - I assume you got the alarm install as well (not just remote start), what happens with the standard remote with this, is it redundant or does it still lock/unlock the van and arm/disarm the Clifford?
TIA
TIA
- mark1a
Sorry one more - with manual transmission, is there anything in the two way comms that would tell you that the remote start has failed because van is not in neutral? I guess the interlock that stops the starter turning if the clutch is not depressed must be overridden by the Clifford too.
- Caddyluv
Yes both remotes work but only the Clifford remote starts yes it has a alarm which you can alarm with your van key and or your Clifford remote and if you open with your car key it send a signal to your Clifford remote to tell you a command has happened. O and if it is in gear it has a safety knock off so it won’t start.
When you start you van as normal you still have to press the clutch as normal. But there is computer magic that involves something else so it Remote starts. Think that’s it.
- mark1a
Nice one cheers, I'll think about this... Got used to warm starts on cold mornings when I had an electric car, I could tell it from the BMW ConnectedDrive iPhone app to preheat the cabin and batteries while it was still plugged into the mains and it would be 22 deg C and ice free when I got in.
- Caddyluv
You can do that with this Clifford you can add it on as a add on. This is like the main part and you can add and add and add and add and add and add. You get it.
- Caddyluv
It’s snowing outside I can load the van while the cab is getting warm coz of my solid bulkhead
- Caddyluv
So done a couple little things this week. Fixed the rattle which I thought was the glove box. But where I had the alarm fitted a cable was tapping where he ran it along behind the dash. So tidy that up.
Bought caddy life mirrors and had the caps painted so it’s all ready for Saturday to be fitted.
Also bought a new scuttle panel as I damage it putting it back I will fit that Saturday to.
Yesterday had a little remap. So currently around 170bhp. It’s all normal between 0-50 gets there a bit quicker obviously, But over that the power just keeps on going even in top gear which is impressive. So happy with that.
- RKDesigns
Parking heater is better. Each time a cold motor have to run parked the oil doesn’t come that high... at the long term its not a super solution. Its better to drive away with a cold engine that the oil gets everywhere. Although the newest engines have that as Well just running. Or use a parking heater, the engine when it gets started it doesn’t have to warm up that long anymore.
Nice looking van mate
- Caddyluv
Thanks swan. Love my van.
Got some gifts today.
1, massive stone chip.
2, some fuddger thought it would be fun to smash my mirror broke the plastic cap.
- Caddyluv
So had couple things done yesterday, firstly was we changed the mirrors to folding caddy life mirrors. Happy with the sleek look.
Then we changed the steering wheel to a multi function wheel. I like the look of this wheel.
Old
New
Also Claudiu sorted that my needles sweep, love that so a good day lots of things done.
Old
New
- Caddyluv
Also changed the rear lights from a F to now a E
- RKDesigns
Haha F is that it looks like a conversion to a Caddy 4 which aren’t coded.
- Caddyluv
Yeah mine was originally F the guy coded it for me to be a E so mine now looks like yours.
- RKDesigns
Should look always with a Caddy 4 like an E from factory.
