Nighteye led h4
Nighteye led h4
Anyone used or using the nighteye led conversion think they have change to (NOVSIGHT)? Ive been told to use the fanless version, also whats a nice led side light to go with the set up ?
Re: Nighteye led h4
I’m looking to use the ambother led for headlights.
Bought some for the wife’s mini and they very good. Good beam pattern also. For the side lights bought some off the bay again for the minster and had some left over will try get you a link.
Also changed all the interior lights and rear plate lights for leds.
Re: Nighteye led h4
Link would be good cheers mate really wona do the number plate bulb aswell, do you know what the side light bulb and number plate bulb type is ? Dunno if you have any pictures ?Pepsi wrote:I’m looking to use the ambother led for headlights.
Re: Nighteye led h4
The sidelights are t10 bulbs
The number plate lights are festoon 36mm or 39mm can’t remember an All interior lights are the same as number plate
Headlights
https://www.amazon.co.uk/gp/aw/d/B072NB ... ref=plSrch
I bought these for the wife’s mini as I said.
Not put them In caddy as have old caddy and the have a twist cap for the bulb. So won’t fit as is as far as I’m aware. Not looked into it properly. May need an adapter
Headlights
Re: Nighteye led h4
Side light bulbs I bought no longer available but looked something like thisPepsi wrote:The sidelights are t10 bulbs
Headlights
https://m.ebay.co.uk/itm/T10-501-W5W-CA ... 8Dz48RiUCQ
Re: Nighteye led h4
Number plate lights
https://m.ebay.co.uk/itm/Festoon-CANBUS ... 1687385419
Just pop the old ones out and check the size
Re: Nighteye led h4
Thanks mate my side lights arent 501 bulbs mine look huge gona pop the headlight out tomorrow and see what they are.
Re: Nighteye led h4
It might be useful to first know which generation of CADDY2K you have, then which headlights. There are a couple of variations for each of the three generations.
Re: Nighteye led h4
Sorry i forget there are a few diffrent models
mines a 64 reg 2015 model 1.6 trendline, dunno if thats enough info ?
Re: Nighteye led h4
Codling893 wrote:Sorry i forget there are a few diffrent modelsmines a 64 reg 2015 model 1.6 trendline, dunno if thats enough info ?
Re: Nighteye led h4
Re: Nighteye led h4
Well said doc. Didn’t think to ask.
On a side note how do I know how many posts I’ve made?
Re: Nighteye led h4
Pepsi wrote:Well said doc. Didn’t think to ask.
2011 Silver 1.6tdi Maxi Panel Van
Re: Nighteye led h4
- Bad666
Re: Nighteye led h4
Just changing both sets of bulbs on mk4 caddy
Inner bulbs 5 minute job, can’t see how you’d get outer bulbs out? Too tight, do headlights have to come out??
