Toffee delights
Lister79
Re: Toffee delights
Post by Lister79 »
Air suspension definitely isn’t a fan of continuous sub zero winter conditions….
Found the tank at 0psi on Tuesday, and with a significant leak which caused the tank to empty after circa 30mins. Unfortunately I haven’t had time to look at it until today, which has meant excessive run time on my compressors (again in sub zero conditions). This has ultimately led to blowing one of the fuses. The compressor appears to be working fine now, so fingers crossed it hasn’t done any permanent damage and was due to temp.
Traced the air leak to be one of the check valves passing. On stripping it it didn’t look too bad, at least no where near as gunked up as the last time I replaced them 2 years ago. Nevertheless I replaced both of them and all associated fittings and lines.
Also drained the catch can which was surprisingly full after only a month or so. I removed the intake just to check there wasn’t any oil residue, and found it to be clean as a whistle, so thats reassuring that the can is doing its job and keeping all that crap out of my oil, engine and intake.
Leak blowing bubbles
Check valves stripped and new
Replaced fittings
Blow 30A fuse
Catch can contents
Lister79
Toffee delights
Post by Lister79 »
Not a lot going on with the van at the minute so it’s nice to get some progress photos sent of the Rotiform lips from C6 Carbon, going to look amazing once Paul’s finished doing the resin. 🤌Image
Looking forward to getting them back now, and the wheels over to wheel unique to get finished ready for summer. Who knows I might get some interest to do a show with these…
Dislexicdonkey
Re: Toffee delights
Post by Dislexicdonkey »
They look awesome dude, I’ve got notifications on whenever you post as I know it’s going to be something special! I absolutely love the Audi wheels mate, I think they have to be my favourite on your car! Are they 20s?
Lister79
Toffee delights
Post by Lister79 »
Cheers mate, much appreciated. Nothing so special happening at the minute other than winter trying to destroy it, and me trying to keep on top of it. I need some nice weather so I get it cleaned up and hopefully get interested again.
Yeah they are 20’s and probably my favorite also, just suit it so well. But I do like to change between the sets I have to give the van a different look.
Dislexicdonkey
Re: Toffee delights
Can I ask if you know if they do them in 19s? And what car did they come from? I’ve struggled like crazy to get wheels to fit over my brembo 18z fronts, and really am at a loose end on how to get a set that will fit or even be able to give dimensions to a company of what wheels would fit.
Lister79
Re: Toffee delights
Post by Lister79 »
I’m not sure if genuine ones come in a 19” version tbh, If not you’d probably be able to get some aftermarket ones in a 19”. Mine are for an A6.
Yeah I’ve always found wheel companies aren’t particularly helpful when it comes to measuring up wheels to confirm fitment, I suspect it’s because they don’t actually know the product they are selling.
Jonny_mcc
Re: Toffee delights
Post by Jonny_mcc »
stunning wheels!
