Caddy front door the same as a Touran?
Davie32
Post by Davie32 » Thu Feb 07, 2019 1:41 pm
Will a Touran front door fit a caddy on a 2007??
Re: Caddy front door the same as a Touran?
Post by Doc » Thu Feb 07, 2019 2:35 pm
Hi, welcome to the forum.
The Touran doors are a different shape to the caddy and therefore are not swappable.
karlos0891
Post by karlos0891 » Sat Feb 09, 2019 12:09 am
i thought only the windows and door mirror mounting area was different. thats what it looked like with a caddy and touran next to each other anyway. rest of the shape did look very similar
ferda5
Post by ferda5 » Sat Feb 09, 2019 6:57 am
I also thought they were the same. When I wanted to replace the mirror from Touran, it was unfortunate, it had to be adjusted, so the door was different :roll:
karlos0891
Post by karlos0891 » Sat Feb 09, 2019 8:04 am
the only difference i noticed is just where the mirror sits even the little window infront of the door looks the same as the touran one. so to me its just mirror part and the glass that have changed sizes so if the touran door is the same in size and shape else where then would be just a swap over and then touran mirrors would just bolt on. i was surprised that they was different as they are both similar especially front end.
dan@biali
Post by dan@biali » Sat Feb 09, 2019 9:03 am
The top of the Touran door and the Caddy door are different profiles.
You can see in this comparison the Touran one is a smoother arc and the Caddy one goes up and then kinks slightly
I've overlaid the two on photoshop and you can see the difference with the Caddy one being slightly taller as well
Beaker2135
Post by Beaker2135 » Sat Feb 09, 2019 9:44 am
This is true, the doors aren’t interchangeable but the door cards are, just a small bit of trimming around the mirror cover
Dandan95
Post by Dandan95 » Sun Apr 28, 2019 9:25 am
Does anyone know if touran wind deflectors would fit a vw caddy?
Post by Doc » Sun Apr 28, 2019 11:18 am
Probably not but it's worth trying if you have Touran deflectors available to check.
If you're buying new, there's proper caddy deflectors available so no point buy the wrong ones.
Dandan95
Post by Dandan95 » Sun Apr 28, 2019 6:15 pm
Ok just asking as there is a guy fairly local to me selling a set of touran deflectors for £10. But the caddy ones are only around £30 on eBay so I don’t think I’ll take the risk lol thanks for the reply
