Wind noise
skinnyd
Wind noise
Post by skinnyd »
So now that the rear is soundproofed and carpeted my attention has changed to the wind noise in the cabin.
Any solutions for this?
Barbel330
Re: Wind noise
Post by Barbel330 »
Do you have standard big mirrors? Wind deflectors make a lot of noise if you have them.
Instagram: @y_5cuf
skinnyd
Re: Wind noise
Post by skinnyd »
Standard dumbo mirrors.
No deflectors.
Giddy
Re: Wind noise
Post by Giddy »
You sure it's not the 'mirror whistle'? It is a topic in 'how to' section https://www.caddy2k.com/forum/viewtopic ... 22&t=16444
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
donnielee
Re: Wind noise
Post by donnielee »
i ve got the same problem had it from new,i did try adjusting the doors to close tighter but didnt do much. i am going to get the duct tape out and seal the door up till i find out where the problem is
skinnyd
Re: Wind noise
Post by skinnyd »
@Giddy. No not the mirror whistle. The noise in the cabin sounds like the window is slightly open
matty_2k
Re: Wind noise
Post by matty_2k »
@skinnyd I have the same issue, I can actually see the outside world through a gap between the door seal and where it meets the body, approx 1-2mm not sure how water doesn’t come in tbh!
activeviii
Re: Wind noise
Post by activeviii »
I did read somewhere about a second door seal. not sure where or how but said to help a fair bit
robblowen
Re: Wind noise
Post by robblowen »
I had a look for that the other day, anyone confirm if it's no.9 and whether it fits and/or makes much difference?Image
skinnyd
Re: Wind noise
Post by skinnyd »
Interesting to know if the life models have extra insulation as well?
Re: Wind noise
The extra door seals are £41.02 from VW including VAT. They are listed as being for, "Comfort equipment", "sports/convenience version" or "high luxury equipment level"
It's on my to do list after I get some money back in my caddy funds piggy bank.
robblowen
Re: Wind noise
Post by robblowen »
Cheers doc
skinnyd
Re: Wind noise
Post by skinnyd »
Thanks @doc.
Does the sliding door also have extra insulation options?
Vw1010
Re: Wind noise
Post by Vw1010 »
Bad door seals is the most common problem with wind noise. I had Them all renewed when ik bought my 180K second hand caddy. Doors are really snug now. Wind noise is a lot less now
Stvxrt
Re: Wind noise
Post by Stvxrt »
has anyone here fitted the comfort door seals? from what I can see on partslink, the seal on the door and on the van will both need replacing. after searching google images it looks like the caddy life has them as standard?
