Fitting dual climate from touran
Hi I'm fairly new starting to do a caddy build ,I've got a/c in my van but want to fit dual zone climate, I have everything I think as I removed from a touran realise it means changing heater box and dash but just wondering how people have wired it in with changing the whole loom CAN anyone help please ?
Re: Fitting dual climate from touran
Hi @Wrcpulsar welcome to the forum.
Changing the climate control will involve some wiring changes but it's certainly not something I'd class as a "whole loom change".
The pinouts are on the forum, in the relevant sections which you won't have access to with only two posts.
Once you meet the criteria for extended access and make the appropriate upgrade request, the information will become apparent.
Ok thanks I heard there are about 8 wires that need to be spliced in I have the dash loom ,just trying to get everything done while off the road just done a v2 touran front end ,touran seat conversion and bls to asz conversion
@Wrcpulsar how did it go? Hoping to do this soon but hunting for parts
hi, any info on the work ? I'am also thinking to put ac in a caddy without it so it could help. thx
No sorry not had time ,been trying to find info on the wires you have to add ,but no one seems to want to help unfortunately
Ive done this to my van. Start by taking the whole dash out, the alloy crash beam behind it which is a fiddly bastard with all the various clips and wiring attached to it as well as the steering column. Then go under the bonnet, take of the wipers and motor and on the drivers side is a 13mm bolt, take this out and then disconnect the aircon pipes and the water pipes to the bulkhead and only then, can you then wrestle the old heater box out.
What did you do about the wiring ? For new Hester box
https://www.caddy2k.com/forum/viewtopic ... 22&t=24830
There's good information in this thread for the wiring and what modifications are required.
I'm staying around until I can access that information. i am upgrading my caddy 1.9 tdi bjb to arl
What are The criterea for accsess?
- Lister79
@Ludde
As per instructions in sign up email and below post
https://caddy2k.com/forum/viewtopic.php?f=3&t=31039
How did you get on did you manage to sort it
- Jeffers76
Im looking at starting this, and I'm guessing that dual climate is the same as climatronic ?
When installing the can wires do they tap into some nearby or go direct to the gateway ?
