Tips for removing accelerator pedal
- DeanWhit
Re: Tips for removing accelerator pedal
OK, thanks for the response... Any tips on how to do it?
There is a How to Guide, I followed it when I did mine: https://www.caddy2k.com/forum/viewtopic ... golf+pedal
I just pulled mine and it came lose
I found on my caddy that removing the carpet from around the pedal first made it much easier to pull it off as you can clearly see how it clips onto the posts.
2012 Maxi build thread - https://www.caddy2k.com/forum/viewtopic ... 13&t=50069
Instagram account - https://www.instagram.com/stealth.caddy/
- DeanWhit
Thanks for all the advice, I'll be giving it a go next weekend.
I just rang my local VW about one of these, to be told it's a tool so only for sale to trade account holders. Halfords sell them though they're pricey there. And out of stock nationwide it seems until next Monday, though that could be quicker than fiddling with screwdriversstan-the-man wrote: ↑Sun Jan 12, 2020 3:05 pm You can get a tool for it at VW. Think it’s was €10.00 or so but that was around 3 years ago. It inserts into slots at the base and releases them. Like a tool I broke my pedal trying to use random tools , then I got myself the tool.
- dan@biali
There are ebay versions and Laser Tools makes a set for about £41 https://www.lasertools.co.uk/Product/79 ... ls-for-VAG which I think is the one Halfords sells for £25.
Thanks I was hoping to get one today from somewhere, silly to be held up for a few days for a 2 minute job! I'll try struggling with screwdrivers for another hour or two before quitting and ordering through Laser.
It turns out the tool wouldn't have helped in my case. I got suspicios with the lack of any movement at all of either locking tab, so prized away the rubber floor and foam to get at the mounting plate nuts. What was presumably mud from boots had seeped through and fossilised everywhere under the pedal mounting points and in and around the release tabs. There must've been a large mug's worth of mudcake to clear out! I removed the 2 10mm nuts (after chipping off enough cake to get a spanner on them) and took out the pedal and plate as one. It the took a good 10 mins to separate them! I should be able to rescue the pedal with a good cleanup (as long as the release tabs havent become too brittle) but I'll have top order a new mounting plate and replace the nuts. Another lesson learnt the hard way.
I’m guessing mine will look like this with the water. Im going to have a go at removing mine this weekend
I found this searching for the LHD version of the tool.
https://www.printables.com/model/135851 ... 0238/files
Maybe it is cheaper to print than actually buying the tool. Im printing it right now and will have a go on a local scrapyard in the near future.
@ Poffe
Let us know how you get on with the 3D print
is your caddy a LHD or are you printing the reverse for a RHD ?
I will for sure! It is already printed and ready. My caddy is a LHD, since Im a swede and live in Sweden
*Removed File* (Since it isnt working)
I mirrored the file and now i guess it is a T10240.
Sent from my Nokia 3310
- Attachments
- 4_Entriegelungswerkzeug_Fahrpedal_T10240.zip
- (4.67 KiB) Downloaded 21 times
For some reason I can't open the attachment...
