Virtual cockpit in caddy iv
Re: Virtual cockpit in caddy iv
I’d imagine so! It was a very easy upgrade overall, the hard bits parting with the cash
Using the same logic I used… these virtual dashes can be retrofitted into any caddy 2004 till 2020 so plenty of options for everyone else
2019 Caddy Highline, Heated screen, parking sensors, cruise, auto lights, virtual cockpit dash, custom blue seatbelts, heated GTE seats, GTE MFSW, climatic, rear camera, discover media nav, oem+ led headlights, GTE tartan doorcards, Audison sound system (project: highest spec highline )
Looks really good and quite tempted myself as this is the only thing left that i miss from my Tiguan is the virtual cockpit.
- Winst
Now that is cool…. Awesome work, well done
2011 2.0tdi Full 2018 front and rear ends fitted, airlift 3P suspension, 20" alloys, modified Porsche calipers front and rear with R8 handbrake caliper, Audi RS4 wingbacks, covered in nappa leather and alcantara, Touran dash, door cards, centre console all trimmed in leather and alcantara, MFSW, 3D cluster, Rockford fosgate and focal sounds with MIB2, bi xenons, full alltrack kit fitted, etc etc:D
Instagram @2kwayne
Instagram @2kwayne
- fishynos72
I'm stupid and keen
Do you have a link of where you've purchased it from?
I know most won't say it supports TDI but you've proven otherwise.
.... and thankfully my van is too old to have adBlue.
Does the screen have the options to change how it looks or colours etc?
Reason: Quote removed
@fishynos72
Yup that was me
Link to what I purchased here:
£525.14 30% Off | Digital Dashboard Panel Virtual Instrument Cluster CockPit LCD Speedometer for VW Golf 7 Golf 6 Passat B7 B6 CC Scirocco Tiguan
https://a.aliexpress.com/_vexdBW
Yup that was me
Reason: Quote removed and tag added
@Autokraft
Yeah loads of different screen layout options and sizes. Can just have a large speedo in the middle or none at all just small digital in the corners if you wanted.
I think you can see on a previous page 4 or 5 I posted some photos and I changed the needle and dial colours from red to blue, there’s a huge choice of colours that’s linked to ambient lighting so if you happen to have oem lighting it will control and match those also
- spacewalker
Anyone can show here is exactly connect and what sub-board contain? Cpu, memory, connectors...
If you watch this video it might help, has a few good
Clips of the board / chips etc
https://youtu.be/6nV9L-hzpp8
- spacewalker
- fishynos72
@EricsCaddy
Thank you for that link.
Does it play nice with your RCD carplay/app connect radio?
Reason: Removed quote and tag added
A nice mod that mate. Well done
@fishynos72
I’ve got a discovery media and it links up with that fine, standard steering wheel controls and stuff all link up and work with it.
The original clocks don’t really link up with the radio anyway but still displays stations and info etc
Reason: removed quote, added username tag
Hi all,
@EricsCaddy, excellent work mate. I definitely want this upgrade. I have a mk4 2.0TDI with standard radio (not discover media) and standard instrument cluster (not highline). All the information is a bit overwhelming for me to understand.
Are you able to explain what I would need to purchase beside the Scirocco digital dash, what mods need to be made to the unit and the fitment of it and does it work seemlessly with the TDI version. Your help would be greatly appreciated
@Servicon
Hey mate, I think you’d need to upgrade to a highline cluster and then transfer the board over into the virtual cockpit as the standard one might not work.
To get it to fit involves trimming the edge and top of the cluster a little and removing a few bits of plastic behind the clocks to get it to fit nice.
Seemlessly isn’t the word I’d use for it though lol everything works great but the mpg is miles off, also a little faffy scrolling the menu since you have to scroll up / down but press ok to confirm what you want on the larger screen.
I think it’s over priced for what you get also.
You gain in some areas but lose in others like the extra details on the original clocks. Eg original will show bulb warning and come up in the middle “check front left fog” but the virtual dash just puts the bulb light on which was abit disappointing
