Maxi workhorse
R22LRM
Maxi workhorse
Post by R22LRM » Fri Feb 28, 2020 10:06 am
Hi all, so I am now the proud owner of 2no caddy’s. As my candy white Tfsi has morphed into a garage queen, I needed a new workhorse.
Let the mods beginImage
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Fri Feb 28, 2020 10:10 am
Hadn’t even owned this workhorse for a day before the seats had to goImage ripped the originals out quick clean and bang new gt sport seats for a measly £50, what a difference they make to comfort, probably the best £50 I’ll spend on this van.
R22LRM
Mk5 Tfsi powered
Ripley55
Re: Maxi workhorse
Post by Ripley55 » Sat Feb 29, 2020 1:37 pm
2 Caddy’s
Now that sounds awesome
I’d love to, but I’m 100% certain, I’d be divorced by the end of the month :lol: :lol:
Chestnut Brown Caddy MK4 Maxi Life 2.0Tdi 150bhp , 18” Audi Alloys 8Jx18 ET40 on 245/40/18’s
R22LRM
Re: Maxi workhorse
Post by R22LRM » Sat Feb 29, 2020 2:05 pm
Ripley55 wrote:2 Caddy’s
The other half isn’t impressedImageImageImage
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Thu Mar 05, 2020 2:42 pm
Few little jobs boxed off today:
Van x led winkle pickers:
Caddy alltrack smoked rear lights:
Gti mk5 steering wheel:
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Thu Mar 05, 2020 4:20 pm
Next jobs gti breaks & stance coil overs:
R22LRM
Mk5 Tfsi powered
Re: Maxi workhorse
Post by Doc » Thu Mar 05, 2020 4:28 pm
You are missing the carriers from the rear brakes in that photo, that's essentially the only part you need as the calipers are a different piston size and not suitable for use on a Caddy.
R22LRM
Re: Maxi workhorse
Post by R22LRM » Thu Mar 05, 2020 7:46 pm
Doc wrote:You are missing the carriers from the rear brakes in that photo, that's essentially the only part you need as the calipers are a different piston size and not suitable for use on a Caddy.
Ahh ok thanks for heads up doc, so the caddy callipers will work with the 286mm discs if I get the carriers?
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Thu Mar 05, 2020 7:50 pm
Think I have some callipers and carriers off my white one that had 282mm rear discs on it when I upgraded to r32 rears will they fit the maxi?
R22LRM
Mk5 Tfsi powered
Re: Maxi workhorse
Post by Doc » Thu Mar 05, 2020 11:36 pm
Without knowing exactly what you have to fit and what is fitted I can't advise 100%, that said I and many others have fitted rear caliper carriers from a GTI and put the caddy caliper onto that without an issue.
R22LRM
Re: Maxi workhorse
Post by R22LRM » Fri Mar 06, 2020 7:43 am
Doc thanks again saved me a bit of head scratching there
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Wed Mar 11, 2020 12:51 pm
Freshly painted rims, wrapped in lovely falken rubber ready coils now Image
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Thu Mar 19, 2020 10:50 am
Easiest modification ever heko wind deflectors:
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Thu Mar 19, 2020 10:55 am
Freshly painted front gti callipers and discs:
R22LRM
Mk5 Tfsi powered
R22LRM
Re: Maxi workhorse
Post by R22LRM » Thu Mar 19, 2020 12:46 pm
Roof bars installed:
R22LRM
Mk5 Tfsi powered
