Just wondering if anyone can confirm if the four digit number on the right is the radio code or not
Tom
Radio code! Is it on this sticker?
Re: Radio code! Is it on this sticker?
radio code is not handed by VW anymore. they input the code and then is stored in the instrument cluster. you can get your radio code off ebay with radio serial number, will cost 10-20£ depending on the radio. I can supply radio codes from serial numbers as well.
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
Thanks for the quick reply. I thought as much tbf, basically i was wanting to sell my original standard one but tbh its probably only worth 20 on the best of days so maybe not worth it unfortunatelyclaudiu2s wrote: ↑Tue Mar 03, 2020 3:56 pm radio code is not handed by VW anymore. they input the code and then is stored in the instrument cluster. you can get your radio code off ebay with radio serial number, will cost 10-20£ depending on the radio. I can supply radio codes from serial numbers as well.
Hello everybody. Recently i changed the battery of my caddy and the radio cd ask me a code.I checked the car papers but i don't find it,but i found a site.I need the serial no to unlock. I removed the radio and my serial number is: VWZ1Z2A1200012.
I searched on the internet but did not find any code. While searching I found a site that gives me the radio code. Has anyone used it? https://radiocodefinder.com/radio-code-volkswagen ? I'm curious if it's a scam or not because I don't want to be scammed. Please help me because i want to listen music while i driving...
