Let the build begin
C Chis
Re: Let the build begin
Post by C Chis » Mon Mar 29, 2021 9:23 pm
Here, here... ban Chris.... whoever he is :D :D :D
2010 pre-facelift Mk3 1.9 Remapped BLS : Touran Interior : 3D Premium Clocks : R32 Bumper : Climatic A/C : Stealth Xenons
My MTB Caddy Build Thread and Details can be Found Here
C Chis
Let the build begin
Post by C Chis » Mon Apr 12, 2021 5:27 pm
Been a little quiet of late... been MTB’ing in the spring sunshine Image
However, gave the old caddy a wash and fitted some rather nice, bargain priced roof rails and cross bars!
Now she looks like a van Image
Off for a wee drive to see how quiet and aero they really are!
Post by the swan fiend » Mon Apr 12, 2021 6:43 pm
Looks good mate. I put some roof rails on mine a few weeks ago. I can definitely hear a whistle at 60 plus. It’s not too bad though.
C Chis
Post by C Chis » Mon Apr 12, 2021 6:56 pm
Hi buddy, cheers!
Yip, same here! A very, very slight whistle at about 70mph, nothing at 65mph, result!
Post by the swan fiend » Mon Apr 12, 2021 10:52 pm
Yeah, my whistle is ok. Rattles or whistling is fine when you know the cause. Drives you mad when you don’t!
C Chis
Post by C Chis » Tue Apr 13, 2021 1:24 pm
Quick update on the wind noise...
Fitted the rubber strips to the channel on the aero bars and now the noise has gone, yay!!! Result!
C Chis
Post by C Chis » Mon Apr 26, 2021 8:41 pm
Just a little update, not done anything extra, just been using the van to get to and from the trails whilst the good weather is here, 57 days on the bounce
And a wee update to the to do list...
1. Dukes of Hazard air horns (so ‘70’s)
2. TV/DVD/multimedia unit for the back
3. Interior unlocking button for the side door - diodes here, to be fitted
4. Engine/gearbox upgrade, power, more power... now a live project, on the search for a nice engine or a full donor car
6. TPMS
8. Climatronic upgrade (parts here, to install along with engine upgrade)
9. Heated seats - Touran leather ones fitted, wiring to do at same time as Climatronic upgrade.
10. Respray
C Chis
Post by C Chis » Thu May 06, 2021 12:53 pm
So, the van developed a coolant leak last Friday afternoon, turns out it was the bottom radiator hose intermittently coming into contact with the power steering pump and it’s worn a tidy hole in the hose!
I thought I’d cured this issue when I bought the correct hose ( 1.9, bls with air con and hydraulic PS).
So looking at the hose coupling I thought that perhaps I could gently prise it apart and turn the outlet pipe, this i did to see if it would give more clearance around the pulley.
Seems it does Image result!
Roll on 6 days, new replacement hose arrives, same part number, same supplier, same price even!
And... when compared to the old one with the now rotated coupling they have the same outlet angle, perhaps the first hose was made on a chilled out Friday afternoon before a party weekend?
Van back up and running with about 30mm of clearance between hose and pulley, result!
