Help with engine cutting out randomly
Re: Help with engine cutting out randomly
How shall I contact you Matias regarding the sgo file? Not sure if I’m allowed to post my email address on the forum?
- Matias
This isn't vcd, but vcp. Vagcan pro. I mean U talk about VDCS.
Sent from my LLD-L31 via Tapatalk
VW Caddy Maxi Life 180 HP
- Matias
Send to me unit id from diag. Part number and sw version. When is car ild, is common changed unit without rewrite label on case. Then I find data and send to U.
Okay, so to clarify, what cable do I need to get, also what software to use said cable.
Also I dont have a clue where ti find the unit id from diag, part number or sw version. If you could tell me where to find them id be gratefull.
Thanks again for all your help
- Matias
U can use this what U bought from ebay.
The Vag can pro lead arrived today.
What way is best to contact you Matias to get the file?
Thanks, Charlie
Thanks, Charlie
- Matias
Post here vag part number of unit and the firmware version and then I upload for example to mega.
Hi,
Put new ECU in today. Still nothing. Exact same faults as before. Not sure where to go from here...
Somehow managed to get it to start...
I cleared all the DTC’s as soon as it started and it died again 5 mins later. Weirdly however it started fine after I turned the key on and off.
I then did a re-scan of the engine and it returned these dtcs (picture below). Didn’t know if any of those could be to do with it or not.
You have checked the wiring harness where I suggested?
I followed the leads coming from both connectors as far as I could and couldn’t see any damage to them.
Just took the van for a drive as it seems alright and cut out once but started straight away again after that.
Scratching my head a bit now...
Under the airbox, behind the passenger side headlight, the wiring harness tends to rub through wires there. Usually seen as white limescale type deposit on the harness fabric tape.
Is this it? It’s the only loom I can see that goes near my air box.
Have checked the white deposit, and it’s only on the surface. Also have check all break offs from that loom anywhere that there is white stuff and it all seems fine.
Yep, there are two looms in there, both engine related.
My be worth trying to manipulate them when the engine is running.
Definitely worth cleaning up that ground terminal and the post it's terminated on.
Sounds good. Il try that tomorrow as well as clean that ground post.
Cheers for all your help mate!
