Daily: 2016 Volkswagen Caddy Panel Van 2.0tdi Dsg Stage 3 plus (Stripped and Sold)
- Chris_Fz
Re: Daily: 2015 Volkswagen Caddy Panel Van 2.0tdi Stage 2
Dq250 swop happiness.
What have been done
Mechatronics harness done
Selector harness done.
Can wires done
Kline wire done
Brake pedal done.
Dsg flaps on mfsw done.
Glass dsg shifter head tested and working done.
What's to do.
Clutch pedal delete.
Gearbox swop
Sleeve bearing to fit.
Selector to be fitted
Dq250 oil cooler
Then coding and then we good.
Will then do at a later stage better clutched and software. So that the car can hold more power.
What have been done
Can wires done
Kline wire done
Brake pedal done.
What's to do.
Gearbox swop
Dq250 oil cooler
-Vw Caddy Pv 2.0TDI 2015 stage 2 + 110wkw / 376nm -
-Nardo Grey & Black Trim
-Rolling on 19" A-line Hostiles
-Owner of Retrofitters
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
Dsg cooler ready for the install. .
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
So today has been eventful
New hose for the passager side rear brake caliper
Manual Gearbox out. Thank goodness. Just in time.
Fingers is broken on the clutch.
And it's burnt to the end of its days.
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
So the dsg swop is complete.
Had to get new drive shafts makes that is slightly shorter.
Dsg cooler in.
Slip ring was changed.
Coding ans a lot a wiring.
Dsg had it's adaptation done.
Clutch pedal delete
Every working the why it should.
Just have a few small issues to solve.
Need to start the car manually.
Stage two file to go back on.
Immo recoding.
Dsg cooler in.
Clutch pedal delete
Immo recoding.
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
So I broke a drive shaft.
Lol.
So quickly made a plan to get a new drive shaft took my chances and arranged a.
Vw Golf mk6 gti dsg passenger side shaft.
And it fits perfectly.
Happy days.
Lol.
Happy days.
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
Re: Daily: 2016 Volkswagen Caddy Panel Van 2.0tdi Dsg Stage 2Plus
So complete Parts list needed for this task
1. Dsg Gearbox 02e ........
2.Selector complete with knob and boot.
3. Dsg cooler / firings / piping.
4. Dsg oil 5.5lt to 7lt.
5. Drive shafts from the dsg car left and right.
6.Dsg gearbox mounts.
7.Gearbox Megatronics plug / Selector plug / custom build harness from box to selector to car electronics.
8. Flywheel and starter.
9.Crank Pilot bearing.
10. Engine bolts from the dsg box.
11. Coding
12.Ecu from Dsg car or a tuner to edit the file at a very costly price
13.Bigger and stronger battery.
Lastly lots of patience
11. Coding
-+2771 027 5064-
-+2771 027 5064-
- Handyandy
Your van's looking great and plenty of photos so we can all see the progress it's like we are all there with you watching you work
- Chris_Fz
Thank you so much .
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
New stage 2 plus file loaded. max boost is 1600 bar
cant go higher my Wifes Hairdryer is stronger than my turbo
but have done the dsg software and its a very lovely ride
-+2771 027 5064-
-+2771 027 5064-
- Chris_Fz
On the rollers .
Just to see what the gain will be. Never had the caddy on a Dyno.
Stock is 81kw and 250nm on the flywheel.
This is roughly 68wkw 210nm on the wheels.
With the mods done.
We getting
110wkw and 376nm on the wheel.
Not bad.
With the mods done.
We getting
Not bad.
-+2771 027 5064-
-+2771 027 5064-
Unbelievable. Love every bit of this van! Well done!
Massive amount of work on your Caddy. Really tidy stuff
Renny
Motorsport Scrutineer
T5.1 CAravelle
T5.1 CAravelle
Incredible work! keep workin on!
Hands down the coolest caddy ive seen yet on here!
- Chris_Fz
@greg1990caddy
Thank you so so much
Reason: Removed quote
-+2771 027 5064-
-+2771 027 5064-
