MFSW Wiring
Riggers82
MFSW Wiring
Post by Riggers82 »
I’m looking to upgrade to a MFSW in my 2014 SWB. I’m aware it will need coding with VCDS and I’ve got someone that can do that for me.
I’ve managed to find a tutorial for a T5 on YouTube but can’t seem to find anything in depth for the Caddy.
In the T5 you have to run a couple of extra cables (one to light switch and one to BCM) can anyone tell me if it’s the same in the Caddy? Or better yet post a link with a decent tutorial! :D
Many thanks 🤙
Papa Bear
Re: MFSW Wiring
Post by Papa Bear »
Lots of in-depth tutorials on here, if you have not requested access yet, you should.
Black
Marmite lover!!!
VCDS
Riggers82
Re: MFSW Wiring
Post by Riggers82 »
I have indeed, only just though👌 Fingers crossed I can find what I’m after! Think I’ve found a compatible wheel and airbag so just need a ‘how to’ guide to help me on my way!
Papa Bear
Re: MFSW Wiring
Post by Papa Bear »
It’s a mine field. But info on here has helped greatly, am now on the lookout for a wheel myself (extra cheap :D )
Black
Marmite lover!!!
VCDS
Riggers82
Re: MFSW Wiring
Post by Riggers82 »
Ive found a company that will do it. Mk6 GTI wheel and airbag, new BCM (apparently that’s needed), and labour £650...
I definitely fancy having a pop first before spending that sort of cash!!
Papa Bear
Re: MFSW Wiring
Post by Papa Bear »
Ouch
Does the new wheel have cruise control?
Black
Marmite lover!!!
VCDS
Re: MFSW Wiring
New BCM!!!
I've never seen a new BCM fitted to a caddy to enable MFSW. Sounds like someone is trying to have your pants down with that description and price.
Papa Bear
Re: MFSW Wiring
Post by Papa Bear »
Rofl love your way with words @doc
Black
Marmite lover!!!
VCDS
Riggers82
Re: MFSW Wiring
Post by Riggers82 »
Doc wrote: Thu Jul 02, 2020 2:50 pm New BCM!!!
Good to know Doc, I’ll question them today... I’m more than happy to have a go myself if I’ve got a tutorial to follow. I did think it was odd as the video I watched on the T5, all they did was wire into the existing BCM...
Riggers82
Re: MFSW Wiring
Post by Riggers82 »
Papa Bear wrote: Thu Jul 02, 2020 1:03 pm Ouch
I will be asking today! Not had a chance to reply to their email quote yet but I certainly don’t want to be paying that price!!
Re: MFSW Wiring
Your caddy is not a T5, there are no wires to go to the BCM and absolutely nothing to do to the BCM in terms of coding or otherwise.
Riggers82
Re: MFSW Wiring
Post by Riggers82 »
Doc wrote: Fri Jul 03, 2020 7:24 am Your caddy is not a T5, there are no wires to go to the BCM and absolutely nothing to do to the BCM in terms of coding or otherwise.
I see... Sounds like I’m being seen off!! :roll:
Any chance you could point me in the right direction of a ‘how to’ thread? I feel like I’m more than capable of doing this myself and saving a few quid... Cheers :D
Papa Bear
Re: MFSW Wiring
Post by Papa Bear »
If wanting cruise on the wheel you will need to do more work involving soldering on a new module from spacewalker.
If no cruise, you will need to make sure everything is compatible but should be a case of install and code
https://www.caddy2k.com/forum/viewtopic ... hilit=Mfsw
Black
Marmite lover!!!
VCDS
Riggers82
Re: MFSW Wiring
Post by Riggers82 »
Papa Bear wrote: Fri Jul 03, 2020 8:16 am If wanting cruise on the wheel you will need to do more work involving soldering on a new module from spacewalker.
That’s awesome! Many thanks 🙏
