upgrade climate control panel
- scatman75
Re: upgrade climate control panel
Lister79 not at all,only 4 screws holds the front part on,then remove the heater matrix ,easy as that...
Sent from my SM-N960F using Tapatalk
- Lister79
Fair do’s mate I thought you meant swapping the plastic housing, as that’s held together by loads.
- scatman75
Everything In and working ,not a big job at all ,only issue was putting the heating matrix back with those silly VW claps,I did my own thing and no leaks ....
- scatman75
dash in ,climate working looking like a new van,will be installing door cards tomorrow to finish it off...
- scatman75
Looking sweet if I do say so myself...
- scatman75
I also wired in while the dash was out and handier to get to ,rain light sensor,Auto dimming mirror and alarm chirp ,will upgrade the CCM to a max one soon so will enable rain closing as well...
Nice work
- scatman75
Cheers mate ,also waiting on tools to come and swap my cluster over,until then I've dremeled the rear of an old cluster to fit in the dash pretty snug .
How did you fit a new cluster mate I’ve been wanting to do that for a while now
- scatman75
ive got ABRITES Commander on its way to reprogram my clusters,my van is a 2005 model so old cluster 4 a imm04 so was easy to read with VAG K+CAN Commander obd,new clocks are 2009 so will have imm04c security which needs different tools,ive just set my existing clocks in the dash for now by cutting the rear plastic to make it fit,it fits pretty snug so will do until my cluster change...
Ha any chance you could code for me
- scatman75
once i get the tool and figure it all out ,for sure ill help you mate..
That would be great bud cheers
Hi Scatman75, did you manage to get the new cluster installed? Would be great to see the finished dashboard.
Also, I recently got hold of a MK4 2017 Caddy Maxi.(wheelchair adapted) I noticed some of the later models (2018 on—>) have dual climate control and was thinking of upgrading mine. Do you think it would be a similar job to yours?
Cheers,
Dean
Cheers,
Dean
Hi,
Just wondering how you got on swapping these panels?
I'm looking at doing the same, just for aesthetic reasons. Will not be installing A/C system.
