The blacker the berry, the sweeter the juice.
BenXCIV
Re: The blacker the berry, the sweeter the juice.
Post by BenXCIV »
Cheers Sarb, just needs some Scirocco dash guages now 😜
BenXCIV
Post by BenXCIV »
Probably the last retrofit for a little while... 😅
Reverse camera wired into the head unit and coded in
nigey47
Post by nigey47 »
Hi where did you get camera from thx
BenXCIV
Post by BenXCIV »
Got it from the bay, here's the link:
https://www.ebay.co.uk/itm/374215428399 ... media=COPY
nigey47
Post by nigey47 »
Nice 1 thanks
BenXCIV
Post by BenXCIV »
Tied up the loose-ends from the previous dash upgrades - installed the looms for the heated seats and park assist button. (Thanks to TommyZooom for these)
Darkside tempted me with the Black Friday 15% discount on powerflex, so ordered the 4× leaf bushes and 2× rear hanger bushes.
Also fit the washer fluid level sensor and swapped back to the stock front grille whilst I sort out some wrap for the All-Track one.
Mgc0407
Post by Mgc0407 »
Hi Ben
Awesome van you have done a lot of great work on it mate.
I just wanted to ask if fitting the aftermarket camera was a pig of a job as i have the same head unit as you and had to buy an RCA adapter to Blue plug for the quad lock connector so i could plug my camera in. But when i select reverse i get the correct screen come up with "Look! Safe to move? but no picture?.
I dont really know whats happening and would appreciate it if you could give me a run down on how you fitted it and the correct coding. I am sure i coded it correctly as it works when i put it in reverse but just no picture comes up.
BenXCIV
Post by BenXCIV »
Thanks for the interest 👍
Sounds like I did the same as you have - bought an RCA adapter and depinned the two wires & repinned them into my existing blue plug (already had one in the back of the head unit - wired to something else).
The coding was a bit of a weird one, maybe that's where your issue is.
There were two options when selecting the reverse camera "type"; from memory they were "reverse" or "environmental".
I naturally assumed "Reverse" was the correct option, but it gave me the same issue as you describe - so I went back in and changed it to "Environmental", and it worked.
For the first week, every now & then it would give me the same black screen issue again, but after parking and turning the car off/on it would fix itself. Haven't had this issue for about 2 months though, so not sure what caused it initially.
If that doesn't make sense, I'll go out and get some screenshots of the coding.
Mgc0407
Post by Mgc0407 »
Thanks for the reply Ben will try it and fingers crossed it works. Looking forward to seeing what's next on your build keep up the great work.
Mgc0407
Post by Mgc0407 »
Hi Ben
I have spoken to the person who codes my car and he is asking for a picture of the codes. If you could get that for me it would be appreciated. Thanks so much for your time i will be so relieved when this is actually working its been a nightmare. :shock:
BenXCIV
Post by BenXCIV »
So:
In Module 5F (Multimedia) I have Byte 19 - Bit 4 "on"
In Module 10 (Parking Assistance) I have Byte 02 - Bit 4 "off" & Bit 5 "on". This gives the output of "Environmental camera installed", like I said before - if I set this to "Rear view camera installed" it doesn't work.. weirdly.
Raph71
Post by Raph71 »
A big thank to you Ben for the discovery and sharing of "anti noise" parts!
I'm looking for all the solutions to fight against noise and the existence of
these parts is very good news!! (Sorry for my english)
Be4ny13
Post by Be4ny13 »
The upgraded stalks look great! What were they from and was the wiring all the same, i.e. did you swap the whole unit or strip the stalks down and swap them individually?
Nath&Alex
Post by Nath&Alex »
Nice Blackberry buddy, also some good info with the part numbers of your mods 👍🏻
2012 Caddy 1.6 TDI Match, lowered with Stance+ coilovers and 18“ John Brown steel wheels
paulfrank
Post by paulfrank »
very nice,good insulation tips
