SOUTH AFRICAN MEMBERS THREAD
- anoneamus
So, it seems it may be useful for South African Caddy owners to share info tips specific to South Africa. So maybe a dedicated thread for South Africans is the way to go...
I'll start: Hi, my name is Ian, I'm a Caddy-holic. I bought my first (and only) Caddy in late 2014, a new (direct from agent) Caddy Cross. I previously had a Golf 4 Cabrio, which got written off in a minor front-end smash (could drive away, but due to A/C condensor and radiator needing replacement, the insurance company decided to write it off). I'd never had a new car before so I went through the new cars section in the CAR magazine and short-listed the entire selection of new cars available in SA down to Caddy Cross and Audi Cross Country. Decided to go for Caddy as it looked like a better camping car (and was about R200K cheaper!). The first dealer I went to said I'd have to wait 4 months for them to order from Poland. I told the next dealer I went to that I would only take the car if they could get me one in less than 72 hours. He combed the country and found one (in my 1st choice of colour) in Durban and had it shipped down by train. Got it in less than 72 hours and have been very happy with it ever since.
I've done quite a few mods to it (mostly OEM parts that may have been available as options if I had one built to order). The most expensive (and satisfying!) one I did was the BiXenon headlight upgrade. The parts price for all of the bits here is insane, so I ordered them from Kufatec in Germany (who thankfully gave me ex-VAT pricing as it was shipping out of Europe).
I use the Caddy as a daily driver and for camping trips. I've built a bed and storage unit for the back, and have added a set of all terrain wheels for back roads. I swap the road and AT wheels around, effectively giving me two different cars (the look, handling and feel is quite different between the two sets).
I have VCDS and VCP if anyone (in Cape Town) needs coding help.
Build thread: viewtopic.php?f=13&t=21198
Camper project thread: viewtopic.php?f=13&t=21093
Re: SOUTH AFRICAN MEMBERS THREAD
hi Ian.
Stunning car
Im also a South African Caddy owner .
1.9tdi 2007
Stunning car
1.9tdi 2007
- anoneamus
Thanks! Where are you based?
Hi
Interesting to see a ZA thread !
I also have a '14 maxi PV 2 TDI that is now a camper van .
I only have 2 issues with it ,
1. Non elecric window
2 no trip computer.
Is there maybe any members that can assist me.
2nd hand power winders maybe ?
What can be done to fit or upgrade the electronic display to have tip computer functions ?
Regards
Nico
2 no trip computer.
Regards
Nico
- alan ditch
AWE fro cape town ....will post pics soon as i can figger it out ...
- alan ditch
Im looking into the same & have been told the touran units fits - same -same ... now just to find them at a breakers !!Zebras wrote: ↑Thu Aug 13, 2020 8:15 pm Hi
2 no trip computer.
Regards
Nico
Hi Alan
Yes I also saw some posts that the parts are "same "
Question is if it is only a matter of finding and fitting a console / instrument panel and problem sorted - or must the new unit be matched or linked
to the rest of the computer system ?
The other question I have have is the correct software / hardware to perform diagnostics on the Caddy range. I have a OBD BT plug but the software
is not working for me .
- anoneamus
There is a lot of information regards electric window refitting on the forum. You'll need to get your post count up to get access to that info. If the instrument panel is an electrical match, the very least you'd have to do is reprogram the immobiliser. If you don't have MFD (multi-function display) you'd probably also have to change steering wheel stalks and steering wheel as well. Caddy and Touran are wired differently, so not all electrical parts can be swapped easily.
In terms of software/hardware the most common solution is RossTech VCDS. It can cover most tasks, with the rest covered by VagCANPro (VCP). Neither of those can do functions like engine ECU remapping, but that's something you probably shouldn't be messing with anyway.
- anoneamus
You'll probably have more luck finding a Caddy, as they're more common. But finding either at a junk yard is rare, seems like people don't write them off often, for whatever reason.alan ditch wrote: ↑Fri Aug 14, 2020 3:37 pm Im looking into the same & have been told the touran units fits - same -same ... now just to find them at a breakers !!
- alan ditch
Thanks for the info .... ah looking for a caddy would be the best option ... ta
Hi upgraded about two weeks ago to this on the left don’t a few changes to it so far.
Lowering kit and wheels fitted two days later
Golf 5/6 Gti front and rear discs and calipers fitted.
That’s all for now
Thanks for looking
That’s all for now
Thanks for looking
- RobbieCT
Howzit guys Rob here from Cape Town
Had mine for 2 years now.
I just want swap out my head lights to the Touran set are they a straight swap?
Sent from my SM-A307FN using Tapatalk
- anoneamus
Which Touran headlights? The dual halogen or the Xenon? Dual halogen just needs coding (with VCDS or similar). Xenon needs wiring harness and additional sensors and modules as well as coding.
- RobbieCT
The dual Halogens yes.
I did read up about the Xenons and it needed the wiring and sensors just could find info on the Dual Halogens
- anoneamus
