Nz R36 build....
Re: Nz R36 build....
What sort of HP you looking at?
- deluxedetailnz
About 325bhp and 350nm ...until I charge it
Thats going to be a lot of wheel spin, torque steer and stains haha
- deluxedetailnz
IainH91 wrote:Thats going to be a lot of wheel spin, torque steer and stains haha
I'll be putting a limited slip differential in pretty soon I think
Insane build
I think that might struggle with that power.
I had no idea this engine would fit, can't wait for some videos
- deluxedetailnz
Ok so engine has had its final fit however we've realised the starter motor we had is pretty done for so hopefully Monday its turnkey time.
One thing I've really struggled for over here is parts. New Zealand is predomantly an auto country so things like starter motors and drive shafts have been a pain getting hold of.
- deluxedetailnz
Also for anyone wondering it was a ttv engineering flywheel for a mk4 R32 that was used.
Here's a pic of it and my pooch otis
- deluxedetailnz
Sl whilst I'm waiting for the starter motor to turn up I relocated my battery to the passengers rear footwell using the oem cable and terminals from the R36 passat.
Re: Nz R36 construire ....
This swap Great job
Caddy 2010 - mk6 gti 312 brakes - mk7 r steering wheel - 18" vw motorsport
- Giddy
If this is a permanent location for the battery, then it looks like that positive terminal is dangerously close to the chassis. Also, the main unfused cable is too exposed underneath and also calling for trouble in my opinion. Would be much safer to keep it inside. Not trying to criticise or anything, just don't want this interesting build to go in flames one day.
I’m no expert on these things but looking at the pictures, I do agree with @Giddy on this.
ditto a fusible link at the very least . Also an excuse for a protective plastic underfloor protection that completes the underfloor aero.
- NZDubNurd
Your NZ certifier "Should" request the battery is fitted inside a box sealed from the passenger compartment.
I have mine in a plastic battery box under the passenger seat.
There are some really cool fuses called a "cube fuse"
I fitted a 300amp? (from memory), to my R32 Touran. The fuse MUST be rated lower than the cable can handle if you want it to actually blow, otherwise the cable causes enough resistance to keep the power on, and just blows molten copper everywhere! It's not about the load applied. Since you're using the original cable, you'll have more than enough power, just get the right fuse.
I used the cable from my donor as well, but it's considerable shorter and takes the same path as yours - same as the original car.
