Caddy cruise control won't go over 74mph?I I
Joelcaddyni
Post by Joelcaddyni »
Hi I have a mk3 caddy with cruise control originally fitted to it and the other day on the motorway I was doing 80mph and set the cruise control for it but it went down to 74mph and you can put up the mph with the button and show on the mfd the speed you want like 85mph but it won't go up by 74mph :(
Any ideas what It can be?
JamesTyrrell
Re: Caddy cruise control won't go over 74mph?I I
Post by JamesTyrrell »
Hate to sound like a pig but wouldn't that be illegal anyway?
Sent from my SM-G988B using Tapatalk
Joelcaddyni
Not at all 🀭🀭
I'm sure there's a setting in some ECU that acts as a speed limiter on cruise control.
Did your van ever have a speed limiter enabled?
caddychris2002
Post by caddychris2002 »
Think you're right doc think its in either module 01 or 09 I've definitely seen it somewhere
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
I'd be 100% certain it's in the engine ECU.
Most likely adaption channels.
caddychris2002
yeah not 09 lol what was i thinking
www.dav-tec.co.uk
Mods:
Joelcaddyni
Yeah it used to have speed limiter but it was mapped but still must be in the cruise control πŸ™„
This sounds typical of speed limiter removal via remapping.
If it's a 1.6TDI it's an adaption channel you can adjust with VCDS but most remapping guys don't have VCDS so they just turn off the limiter function in the map and forget about the cruise control limit.
Joelcaddyni
Okay mate I have vcds there so I'll give it a go cheers 😎
Joelcaddyni
Doc wrote: ↑Mon Feb 01, 2021 9:04 am This sounds typical of speed limiter removal via remapping.
How do you adjust it mate
caddychris2002
Got to engine 01 > adaptation in the drop down menu there is one labelled speed limiter or something similar select that and change what ever the figure in the box is iirc
www.dav-tec.co.uk
Mods:
Joelcaddyni
caddychris2002 wrote: ↑Wed Feb 03, 2021 8:30 am Got to engine 01 > adaptation in the drop down menu there is one labelled speed limiter or something similar select that and change what ever the figure in the box is iirc
Thanks mate 😎
PAULGYE
Post by PAULGYE »
I'm new to this group do you know the access code for speed limiter adaptation on a vw caddy 2007 2.0 sdi
Thanks paulgye
