Bbs CH-R
Glen G
Bbs CH-R
Post by Glen G »
Howya lads looking to buy some original BBS Ch -R having trouble finding them in the right size lol
I looked on a few websites but when I type in caddy 2007 keeps saying so match's for this car etc...
Who would you recommend buying original wheels from ? And anyone no exactly right size offset I need
Re: Bbs CH-R
What diameter wheels do you want?
What wheels have you got on at the moment?
Is you van lowered?
crysisjim
Re: Bbs CH-R
Post by crysisjim »
Hi ,
I have buy mine on ebay from a seller named "felgen-online" mine is for BMW F20 but the seller have lot of other dimensions hope it's help you :D
caddy4mo
Re: Bbs CH-R
Post by caddy4mo »
Following.
I’ve had the same issue not finding.
Oggy172
Re: Bbs CH-R
Post by Oggy172 »
Holly thread bump batman.
I'm looking to get her some bbs ch-r.
They'll need to be 19" flavour with the forge brakes we have, I guess.
Its lowered on stance+ coilovers, not slammed though. Any ideas on the offset id need? And/or spacers.
dan@biali
Re: Bbs CH-R
Post by dan@biali »
I believe the set I have is 19x8.5 ET48 with 225/35/19 tyres. Unfortunately the invoice doesn't list any of the specs. None of the wheel suppliers think you can fit 19s to a Caddy so their suggestions are 18" or smaller. I was lowered on KW coilover kit and I have the wider rear axle (if you had factory fitted 16" steels then possible you have the wider axle which is +5mm per side) and had no rubbing.
dbdigi
Re: Bbs CH-R
Post by dbdigi »
I'm looking to fit Vw 17" alloys to my 2015 maxi . Could someone please suggest best tyre size to fit for a non lowered van? Maximum size tyre without any issues?
Scoobysrt
Re: Bbs CH-R
Post by Scoobysrt »
Best tyre size and maximum tyre size are two separate things.
You should always try to keep the same rolling radius to avoid speedometer and handling issues etc.
What size 17"s are you looking at?
www.willtheyfit.com
Oggy172
Re: Bbs CH-R
Post by Oggy172 »
dan@biali wrote: Sun Jul 02, 2023 6:27 pm I believe the set I have is 19x8.5 ET48 with 225/35/19 tyres. Unfortunately the invoice doesn't list any of the specs. None of the wheel suppliers think you can fit 19s to a Caddy so their suggestions are 18" or smaller. I was lowered on KW coilover kit and I have the wider rear axle (if you had factory fitted 16" steels then possible you have the wider axle which is +5mm per side) and had no rubbing.
Thanks for the reply, I still havent done anything, been a bit lazy... However we had a blowout on the A1 yesterday and cracked a rim.
Current alloys are 19x8J but no idea who makes them - they have Wolfsburg Edition centre caps, but the markings suggest they are Zumbo R0025 - however I can only find them in China/Russia :lol:
Struggling to read the offset on them though. I guess if I whip all 4 off I'll be able to work it out, but the weather is pony and I have the e208, she can drive my 911 so aside from the increased fuel cost, I have a bit of time. Just need a dry weekend.
Damo2k
Re: Bbs CH-R
Post by Damo2k »
19 x 8j et45 is a nice fit to mate
