Front assist
Posted: Wed Jun 16, 2021 7:23 pm
by garethrs1800
Hi lads has anyone done a cluster upgrade and lost the front assist ,after changing my cluster my front assist comes up saying not available it’s really doing my head in lol
Re: Front assist
Posted: Wed Jun 16, 2021 7:33 pm
by Doc
Best go back to whoever did your instrument cluster upgrade and have them finish the job.
The front assistant radar has component protection which needs to be matched to your new/replacement instrument cluster.
Re: Front assist
Posted: Fri Jul 09, 2021 5:34 pm
by garethrs1800
So do you know anyone who can fix this issue for me for me doc must be someone out there who can sort this issue out
Re: Front assist
Posted: Fri Jul 09, 2021 8:33 pm
by zu11y
were abouts are you based. chances are its a coding issue on the cluster. wont be cp as the cluster matches to the car and not the other way so cp would not have kicked in on the radar.
Re: Front assist
Posted: Fri Jul 09, 2021 11:39 pm
by Doc
I stand corrected.
Apologies if I've put you up the wrong path @garethrs1800
Re: Front assist
Posted: Sat Jul 10, 2021 8:59 pm
by garethrs1800
It’s definitely something to do with the cluster wen we put the old cluster back in all is fine wen the new cluster is then put back in all is ok for a short while then it comes up front ads not available that’s all I want is someone to sort it for me any ideas Doc please
Re: Front assist
Posted: Sat Jul 10, 2021 9:04 pm
by Doc
Definitely sounds like component protection but the guy above says not.
One of the reasons I don't do instrument cluster retrofit jobs on Caddy4 is because of the component protection, I don't have the equipment to do it.
Hopefully the previous replier can advise better as I would like to know myself.
Re: Front assist
Posted: Sat Jul 10, 2021 9:40 pm
by zu11y
how are you switching between clusters do you have access to any diagnostics odis/vcds.
i need to have a look at the fault code with the new cluster connected to assess the issue.
there are a number off issues which can shut down the acc.
if you have vcds let me know and will arrange a time to teamviewer in.
Re: Front assist
Posted: Sat Jul 10, 2021 10:11 pm
by garethrs1800
Send me over your number please mate
Re: Front assist
Posted: Tue Jul 20, 2021 9:02 pm
by garethrs1800
Still looking for anyone who’s able to go this for me
