Flat bottom steering wheel
Cov-Caddy
Post by Cov-Caddy »
Looking for advice on which flat bottom wheel will fit my 2012 caddy
Giddy
Re: Flat bottom steering wheel
Post by Giddy »
Any VAG wheel and some others will fit, if just a fit is your requirement.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
Cov-Caddy
Post by Cov-Caddy »
I wasn’t sure if certain ones are meant for certain year vans ?
Cov-Caddy
Post by Cov-Caddy »
Does anyone know the easiest fit I should be looking for ?
Mk5 golf ?
Is it just plain flat bottom, no multi function that you are looking for?
If so, they are all gonna be the same level of work to fit.
Cov-Caddy
Post by Cov-Caddy »
https://en-gb.facebook.com/marketplace/ ... _type=post
Just one like this I’m thinking mate ?
Link isn't working for me, is it a steering wheel with buttons on?
Cov-Caddy
Post by Cov-Caddy »
It’s just a caddy one I think but flat bottom no buttons etc,seen a mk5 gti one but it’s a minefield on which is right 😁
Cov-Caddy
Post by Cov-Caddy »
No minefield, if it's not got buttons it'll go on with no stress.
Cov-Caddy
Post by Cov-Caddy »
Polo GTI one is nice 10-17 £350 their pricey
Gary.8
Post by Gary.8 »
This is the one he's referring to...
so should fitImage
Cov-Caddy
Post by Cov-Caddy »
That’s the one mate,I’ve seen a polo GTI also but at £350 I may get the one you’ve seen
Cabbs
Post by Cabbs »
[mention]Cov-Caddy [/mention]
That will fit mate.
Remember to remove the earth from your battery before unplugging the airbag or you will have an airbag light left on your cluster. Easy to remove if you have vcds but will save you some money if not.
Francis0990
Post by Francis0990 »
Exactly what I was looking for seems straight forward enough then as I don't plan on using multi function wheel
