Yes the steering wheel swapped straight over
Mike’s oem+ caddy build thread
Re: Mike’s oem+ caddy build thread
Been making some decent progress on this recently. Had a touran cluster coded then I fitted it into the van.
Then I had the dreaded top end rattle. Turned out to be the typical worn camshaft. Bought the kit from dark side and done it in a day.
Most recently I’ve been doing the touran rear seat conversion. I’ve still to clean the seats, fit the seatbelts and source the correct caddy life trims but it’s looking good so far.
- Lister79
Good work mate, it’s keeping you busy.
Thanks, it certainly is. Just have to keep on telling myself to keep this as my sensible vehicle
