6 speed gearbox conversion cruise control
BlackEdition
Post by BlackEdition »
Sorry if this is in the wrong section i don't have access to post in other categories
so 2016 Caddy 2.0 tdi DFSD 6 speed conversion i have compiled my list of parts, but before i go ahead does anybody no if
1. do i need to change my mapping for 6 speed if so i can do this myself easy enough just a heads up
2. what have you done about keeping the cruise control as i'm not sure if it will work with the gearbox i have
thanks in advance
2017 caddy black edition
2016 caddy startline
2011 british gas blue maxi
seem to have a caddy problem and its all i seem to work on
antcaddy
Re: 6 speed gearbox conversion cruise control
Post by antcaddy »
I've done the same. I did a bit of mapping myself so it was a case of changing the gear ratios and flashing the ECU. The van still run before I did flash it and sometimes it would think it was in 5th and the cruise control worked. Then other times it didn't. It's a great upgrade and worth the effort. Hope it goes well
Sent from my ONEPLUS A6010 using Tapatalk
BlackEdition
Excellent appreciate you reply, think ill just bang it all together change the map for 6th gear and see how it goes
DJOHALL
Post by DJOHALL »
@BlackEdition what car did you get the 6 speed conversion from? It's on the long to do list for my van.
Sent from my SM-G780F using Tapatalk
Thegibbon
Post by Thegibbon »
Doing this at the moment with a 1.6TDi. By all accounts the issue is with the ECU, softwares different.
Unsure how the EDC responds vs the PCR ecus on the 1.6 but bought an ECU from the touran that the 6spd set came from incase there were other weird differences in the coding options that would also need to be changed to get the cluster to accept 6spd coding.
Davidmorris
Post by Davidmorris »
@antcaddy
Any chance you would fancy doing the same to another van I cant find anyone willing to do the ecu side of things .
antcaddy
Post by antcaddy »
Sorry to disappoint but it's not something I'd do due to the risks involved
Davidmorris
Hi sorry for the late reply I managed to sort it in tbe end fair bit of time trying like bit I got there in the end
rbu_tuninq
Post by rbu_tuninq »
any details of what’s involved…
got a DFSD 2.0 5sp manual at the moment.
what’s needed as parts…
what 6speed gearbox code works.!?
will i need new drive shafts!?
found o2q gearboxes but any o2q ??
not worried about 5th6th speed cruise and or the start stop working…
just want the newest gearrbox possible of which cars would work.
any details would be appreciated
antcaddy
Post by antcaddy »
MQ350 TWH is the box I used. It's harder than the one from the 150 caddy which 6th gear is pointless
NFZ is the one they fit in the 150 but my brother changed it to a TWH due to it being to easy
Yes new drive shafts needed
Used the same cable as it's hardly different in length
Hope that helps
R8umar
Post by R8umar »
Antcaddy, what driveshafts did you use?
I'm having major issues with mine.
I have used the PDT gearbox out of a GTD golf mk7. I did the install about 2 years ago. I used original drive shafts but can't remember if I switched the gearbox flange cups from my 5 speed over to the new box it was that long ago
Basicly that box broke as the casing got damaged and i replaced it for another PDT gearbox that a mechanic fit.
I was running original drive shaft but I've been through 4 drive shafts in the space of 2 months since that 2nd gearbox has been fit.
Some advice would be appreciated
Sent from my SM-S918B using Tapatalk
antcaddy
Post by antcaddy »
@R8ruma not sure how you managed to fit your original shafts as they 5 speed are too long so that might be the issue. You'll need to get the shafts off a 6 speed
R8umar
Post by R8umar »
Thanks for coming back to me
I did order 6 speed shafts but the garage said they were too short??
Davidmorris
Hi sorry for the late reply my van at the time was a 1.6 cay so I used all the gearbox/shafts from a touran
. I now have s 2.0 dfs myself so will start looking in to things and let you know if you have not already sorted things out .
Mattlevant
Post by Mattlevant »
antcaddy wrote: Wed Dec 27, 2023 9:20 pm MQ350 TWH is the box I used. It's harder than the one from the 150 caddy which 6th gear is pointless
Hope that helps
Do you happen to have a list of parts numbers I'd need for the conversion?
2.0 dfsd 5sp currently
With the TWH box what rpm are you at when cruising at 70?
What was needed to get cruise to work in 6th?
