Toilet TFSI - Caddy4
- ToiletTFSI
Re: Toilet TFSI - Caddy4
Finally time to rip the 1.6tdi out…
Enjoyed reading this so far!
Sounds like it’s going to be one epic build that’s for sure, keep up the good work
2019 Caddy Highline, Heated screen, parking sensors, cruise, auto lights, virtual cockpit dash, custom blue seatbelts, heated GTE seats, GTE MFSW, climatic, rear camera, discover media nav, oem+ led headlights, GTE tartan doorcards, Audison sound system (project: highest spec highline )
- Lister79
That’s how to start a build thread . Looking forward to seeing it progress, any timescales in mind or just when’s it’s done?
- Giddy
This is going to be an interesting build
Looking forward to seeing further updates
- ToiletTFSI
Cheers guys… no real time frame as I am still in the old one but would be nice to use in some nice weather!
- ToiletTFSI
Engine out:
- ToiletTFSI
Old steel sub frame, shafts and arms off. Then installed the aluminium subframe temporarily to support the steering column.
- ToiletTFSI
TFSI loom unwrapped.
anyone about to do this... these are a must (thanks Doc )
https://www.amazon.co.uk/gp/product/B08 ... UTF8&psc=1
- ToiletTFSI
Clutch pedal removed... won't be needing this!
- ToiletTFSI
Diesel tank dropped...
For all those who want to do a tfsi swap from a diesel... the difference between the two tanks is quite a lot. I wouldn't convert the diesel to take petrol.
Plus we noticed the petrol is now lined with a white coating - maybe to do with the amount of ethanol creeping up in fuel now.
- ToiletTFSI
New petrol tank, lines installed, with the gti fuel pump wearing the caddy hat to secure it in place. Going to about 360bhp, the standard fuel pump is more than enough.
Also properly painted and lacquered the tank straps.
- C Chis
Cracking build!
Really, really nice to see a build getting done with the right parts and also with all the supporting mods to make it as OEM as possible!
- ToiletTFSI
Thanks Chis…
A little more wiring done today… anything relating to the tdi has been removed and tfsi fuse and relay board installed…
- ToiletTFSI
Then installed all the vibra-technic engine mounts bar the small dog bone insert which I need to freeze first before inserting.
- R22LRM
Great build, going to an absolute weapon
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
