Let's see if I can get a reply to this one
Has anyone fitted / is it even possible to fit an internal handle to open the tailgate from the inside?
Tia
KLS
Tale gate internal door opener
- KLS
Tally Ho!
- fazer909
Re: Tale gate internal door opener
I came across this post on Facebook Caddy Campers group on how to install a release button .... .
https://www.facebook.com/groups/1168727 ... 0420413636
A simple push switch has been used to open the tailgate. Simply splice wires into the release handle wiring - Operates in parallel with existing release button and won't work when the outer button won't.
- KLS
Thanks @fazer909, I'm a member of that group so will check it out, put a post up but didnt think to search!
K
K
Tally Ho!
- KLS
Thanks @petrev, seems simple enough! I'll have a look at at the wiring today, thanks for the heads up.
K
K
Tally Ho!
2 wires - Switch shorts to Open.
- KLS
Ordered mate thanks.....will put one on dash and one on tailgate
Tally Ho!
Great Idea ! Thanks
