ASBO PD130
Azz03
Re: ASBO PD130
Post by Azz03 »
[mention]the_fid [/mention]I did think it was fabricated fair play mate looks a lot better then mine I need to have mine sorted as it worries me with it being close to the bottom pulley
the_fid
Re: ASBO PD130
Post by the_fid »
The pipe should move with the engine but I always keep it a little further away for peace of mind
James
ASBO Performance
400BHP 1.9TDi Caddy
Azz03
Re: ASBO PD130
Post by Azz03 »
[mention]the_fid [/mention] that’s what worries me so I’ve put a pipe clip on it and fixed it to the body of the van underneath with a little space so I can move under tension but not enough to touch the crank wheel. Also wrapped the section of the pipe which is close to the crank with a sleeve to protect it, think im going to have another one fabricated to fit better. Where are you based?
the_fid
Re: ASBO PD130
Post by the_fid »
We are in Kent if you need one making up
James
ASBO Performance
400BHP 1.9TDi Caddy
Azz03
Re: ASBO PD130
Post by Azz03 »
[mention]the_fid [/mention] if you don’t mind me asking where did you get the silicone hoses for the oil cooler and other little bits I found a full silicone pd130 kit online but I was told recently by the company I won’t be able to get it to work with my van not sure how true this is after seeing the hoses in your engine bay. Thanks
Adlewis90
Re: ASBO PD130
Post by Adlewis90 »
Won't miss that on a dark night!
