Page 2 of 2
Re: Mk4 mfsw retrofit help
Posted: Thu Dec 29, 2022 3:35 pm
by Doc
Start with the coding from the original module in the new module, then edit to add MFSW and cruise control.
Posted: Thu Dec 29, 2022 3:51 pm
by MrMagic
Hiya. I did mate it didn’t work.
It’s just a thought but wiring loom for airbag needs repinning? Maybe pins in wrong places? Like on my original one I’ve got blue/white and new loom that came with steering wheel there’s grey in there. Also what I thought of it could be trying to pull out ribbon out of my original one (BB) and put it on the new (L) one. I soldered the broken ribbon but never know it’s so flimsy it could have a loose connection?
Posted: Thu Dec 29, 2022 4:18 pm
by Doc
What was the reason for going for the coding you have in the new SWCM, what did you base this on if not the original with the changes I described?
I don't have a table to decipher each byte so cannot say what coding you have in there or whether it is correct or not.
Airbag harness looks correct, blue/white is the horn, grey is LIN to MFSW module. On MFSW, the blue/white is to the MFSW module rather than directly back to SWCM.
Posted: Thu Dec 29, 2022 5:19 pm
by MrMagic
Hi again Doc
To be honest I don’t think I’ve changed coding, but what I’ve noticed was different van number and different coding after I’ve changed slip ring Is it poss for the coding to change itself by changing slipring? Sorry if that’s a dumb question. Steering wheel is from a polo or at least that’s how it was advertised and airbag is my original caddy. Pics below might help to solve this mystery. Maybe something is not compatible with the rest of it.
Posted: Thu Dec 29, 2022 7:00 pm
by spacewalker
If swcm is ok, It might not work in VW because is from Audi.
And could be-it not corresponding with vw mfsw
Posted: Thu Dec 29, 2022 7:10 pm
by MrMagic
Hi mate.
How can I check if it’s from an Audi or vw? It says vw on stickers
Posted: Thu Dec 29, 2022 11:13 pm
by Rhinopower
Audi swcm modules work fine in VW, I’ve used plenty.
I did a caddy on Monday with those same buttons, and cruise via stalk. I used an E module from a 2012 Leon
Posted: Thu Dec 29, 2022 11:47 pm
by MrMagic
Hi mate. My original module was BB. According to rosstech website BB module does have a steering angle sensor where E doesn’t have it. I’m proper getting confused now
Posted: Fri Dec 30, 2022 1:36 pm
by Rhinopower
Ignore steering angle sensor. You have g85 in the rack so will always be coded without it active on the swcm
Posted: Thu Jan 05, 2023 4:14 pm
by MrMagic
My caddy is dsg. Is E module will work with it? It says on rosstech website something about E only works with kessy and doesn’t support coding for auto box ?? Cheers
Posted: Sat Jan 07, 2023 11:51 pm
by Rhinopower
E works with non kessy too. You’re overthinking it now
Posted: Tue Jan 10, 2023 3:21 pm
by MrMagic
Afternoon Rhinopower
Right I’ve just installed E module and looks like it’s all working. Thanks a lot for all your help mate. Next on wish list to do are caddy life mirrors so surely I’ll be asking for help lol. Thanks again
Posted: Tue Jan 10, 2023 3:24 pm
by MrMagic
Forgot to mention there was no coding needed by the looks of it I’ve just plugged it all in and it’s all working as it should. Is there anything I should do or change or just don’t fix it if it ain’t broken?
Posted: Sat Jan 21, 2023 11:11 pm
by Rhinopower
Glad it’s all working. Nice one
