Footwell lighting
Re: Footwell lighting
Brilliant that is any info on exact parts used and also the ignition surround please
https://www.ebay.ie/itm/281800732252?mk ... media=COPY
Not sure about ignition surround. I know they come from Japan. I know the website but can’t make head nor tail of it as it’s in Japanese
. Stanthevwcaddyman supplies them
Awesome mate thanks , topwork, leds fit as they are or any resistors required ?
No problem! These ones come with resistors already so good to go
Thanks mate
@Garycloona
hello, your car is pq35 platfrom? I'm talking about the lighting in the door pocket. After connecting the 25th pin, did you code from vagcom?
Reason: removed quote, added username tag
- Carpmaster
Just orded some great little mod pal
did you just wire them into your fag lighter
Hi, yeah it’s pq35. Pin 25 should already have a wire in it as this is switch illumination for the door switches. No coding.omeriimm wrote:@Garycloona
Thanks lad! The 2 small ones? They are wired into the cig lighter illumination ring.Carpmaster wrote:Just orded some great little mod paldid you just wire them into your fag lighter
- Carpmaster
Yes mate the small 5mm red ones I've ordered is your cig lighter a content feed? As mine is so just thinking how to do it as I only want them come on when I've got my side lights onGarycloona wrote: ↑Sat Jan 07, 2023 9:55 pm Thanks lad! The 2 small ones? They are wired into the cig lighter illumination ring.
The illumination ring has its own supply in my van. There’s 3 wires
Carpmaster wrote: Yes mate the small 5mm red ones I've ordered is your cig lighter a content feed? As mine is so just thinking how to do it as I only want them come on when I've got my side lights on
Got mine yesterday , could the black go to ground and the red go to grey / blue as that’s the switched illumination feed I think
CorrectMbgasplumbing wrote:Got mine yesterday , could the black go to ground and the red go to grey / blue as that’s the switched illumination feed I think
I only ask that so I could keep the bulb in the cigarette lighter illumination , looking forward to doing this mod as it’s a really nice touch .
