Footwell lighting
Garycloona
Re: Footwell lighting
Post by Garycloona »
Carpmaster wrote: What size drill bit did you use pal
8mm for the type I used. I just use ya vernier caliper to figure it out
Carpmaster
Post by Carpmaster »
Garycloona wrote: Sat Jan 07, 2023 10:25 pm Image
Hi mate where is your black wire connected thanks
Garycloona
Hi, it’s connected to the ground terminal that touches the metal housing of the socket. It’s a bit awkward to get to.
Carpmaster
Garycloona wrote: Thu Jan 12, 2023 9:17 pm Hi, it’s connected to the ground terminal that touches the metal housing of the socket. It’s a bit awkward to get to.
Right got ya yeah can see the other piece off metal not the best to solder on lol
Garycloona
No it’s awkward alright I dismantled the whole thing so I could get access a bit easier. You could always solder it to the outside of the cig housing too
Carpmaster
Garycloona wrote: Thu Jan 12, 2023 9:21 pm No it’s awkward alright Image I dismantled the whole thing so I could get access a bit easier. You could always solder it to the outside of the cig housing too
Yeah think I'll do that but easier lol 😂
Damo2k
Post by Damo2k »
Garycloona wrote: Here’s more ideas for ya! ImageImage
Hi mate nice job...
Have just ordered myself some of these leds.
Wat kind of wire do u use for joining 1.5mm?
Cheers..
DaanBogers
Post by DaanBogers »
Most probably there is someone over here who can help me.
Ive installed a small led strip near the foot wells, and want to have them white with doors open, and red when driving at night.
I wired them as follow;
Positive white led; White BCM connector pin 43
Negative white led; Brown BCM connector pin 10
Negative red led; Brown BCM connector pin 10
Positive red led; blue/grey wire in the light switch connector.
The white leds work as they should, but the red leds also go out with the white leds.
I guess this has to do with the negative current from pin 10 also turns off when the doors close. I think I can fix this by adding an additional negative wire for the red led.
But, I also see other people having these lights with only 3 cables connected.
Am I missing something here?
xtrnisse
Post by xtrnisse »
Very neat little lights! Where did you get those from? :)
Pollytron
Post by Pollytron »
Hi Guys
I'm trying to install some footwell lights to my MK4 Caddy. I've found the CCM and taken the middle plug out but there is cable already occupying pin 50 where I thought the footwell lights should go? Am I missing something?
Ollie
CaddyPZ
Post by CaddyPZ »
These light upgrades look superb! Nicely done 👌🏼
Problem is they’re dangerously encouraging for a new Caddy owner like me! 😆
ruthere
Post by ruthere »
Bruh this light upgrade is dope, do you guys have of this kind of lighting.👇
Bousfield19
Post by Bousfield19 »
This looks cool as hell I'm definitely going to look at it for mine
wilosn02
Post by wilosn02 »
Mbgasplumbing wrote: Sun Jan 01, 2023 8:04 pm Caddy footwell light , struggling to find a good flat location to mount the drivers side footwell light any tips or tricks please, do vw sell and specific holders for these to tuck under the dash ?
VW may offer specific holders or brackets for footwell lights, but it's best to check with a dealership or online parts store for compatible accessories. Finding a flat location under the dash can be tricky, but explore the existing mounting points or use adhesive-backed holders for a clean installation.
samyam1
Post by samyam1 »
Is there anyone in the midlands that does supply and fit wouldn’t mind these!
