I've got a 2006 Caddy SDI and I've just fitted touran electric doors, heater box with air con and new dash.
I need some help with the wiring because only the fan is working. I think the plug that goes into the climate control needs repinning to get power to the temperature adjustment flap.
My old heater box had a cable mech to adjust the heat but the new one has a motor.
Any ideas where to start?
Caddy 2006 SDI BST, HNN gearbox, which loses oil through seals if I go over 3k revs
Touran dashboard, electric windows, rear seat conversion, fully sound deadend and carpeted.
Resprayed indium grey outside my house using rattle cans, a pop up tent and a fishing bivvy.
Paintwork looks great in the rain
Thanks for the reply.
I'm waiting for my account to be upgraded so I can't view that thread yet.
I've bought an online manual with some wiring diagrams but they don't make much sense to me haha
I've actually already bought a manual that seems to have a load of wiring diagrams.
There doesn't seem to be any pictures of the pins though.
So I've downloaded some info from Erwin which gives a bit more info but the colours of the wires don't match.
From what I can work out the only plug i will need to change is the T20 which comes from the main wiring loom and can bus?
The other 2 plugs are for the fan control and then the 16pin plug is what's connected to the heater box assembly.
The only thing that currently works is the fan, no lights to the buttons and neither air recirculation flap or the heater temp flap work. It does seem that it should be just a case of re-pinning the T20 plug?
The original cable that came with the climate control unit has 8 wires whereas the one in my caddy only has 7. I think this is because I didn't have air con or because the new climate control has a heated window button?
This is what I found in the manual but mine doesn't have buttons for heated seats.
20-pin connector, T20c in current flow diagram
3 - Air recirculation flap control motor - V113-
6 - Air recirculation flap control motor - V113-
8 - Rear window
11 - Heated driver seat control unit - J131-
15 - Heated front passenger seat control unit - J132-
16 - Terminal 75, seat heating (optional)
18 - Terminal 30
19 - Terminal 15
20 - Terminal 31
I have picture of the plugs but there doesn't seem to be an option to upload them, is this a restriction on my account?
Yes I think it is from a Touran, feel like I'm getting closer.
I requested more access to the forum a few days ago but I still can't access the thread you mentioned which seems to be what I need. Do you know how long it takes?
Thanks for your replies, do you know anyone based around Cheshire that is any good with wiring?
I am not sure how long it will take, normally days to a week or maybe longer, depending on how busy the Admins are.
I do not know anyone around Cheshire. I think you have done the hard part already which is the install, the wiring is straight forward, just study the wiring diagrams for a while.
Those tutorials were really good and I've got a better understanding now
Still struggling with wire colours though, can someone please copy the pin diagrams from the thread mentioned above as I still can't access it?
My original climate control is 2K0819047C
The new one is 1K0820047FT
Good to see you want to get this completed, however as a rule we’re not keen to copy info from the tech section as it kinda goes against the forum ethos to contribute before getting access. This policy helps make the forum grow and access to the members only technical section once you’ve fulfilled the criteria that have met the minimum contribution criteria even better. Your upgrade will most likely come through in a few days or so.
The upgrade process is a manual one and carried out by a limited number of people who are fitting it in between other stuff. As mentioned above, this is normally done on the weekend after submitting but sometimes takes a little longer.
I dont believe posting info from the Technical/ How To parts of the form on to the chat page is allowed. Gaining access to this info comes part in parcel when you join up and have full access.
