Engine cover mounting problem
Raph71
Post by Raph71 »
My engine cover is just laid like this. It is not fixed because the small plastic pin of the external element supposed to hold everything is currently sailing freely in the hole of the rocker arm cover. Do I have the wrong engine cover or is there a rubber piece that fits to block everything? If so, does anyone have the part number? I would like to take advantage of my change of front face to completely clean my engine, which has not been done since the purchase of my Caddy 10 years ago Image and I would like to take the opportunity to put good insulation back under the cover, the paint and fix it properly this time. In the how to parts Numbers section, I found 07C 103 226. Would that be okay? I’ve a Doubs..Image Image
Envoyé de mon iPhone en utilisant Tapatalk
dan@biali
Re: Engine cover mounting problem
Post by dan@biali »
Can you show which engine cover you have? Or do you know the part number (its usually on a sticker or marked on the bottom)?
C Chis
Post by C Chis »
There should be a small rubber grommet in there to secure the cover pin.
It should look like this… I don’t know the part number though. I swapped the engine out last year
Raph71
Post by Raph71 »
@dan@biali
@C Chris
yes, it’s definitely a rubber part but what I found on web (reference on my first post) does not seem to be the correct one. Putting the pics here at Dan's request, I just thought I'll try to find the part on the ETKA schémas from the plastic cover codes. To be continued!..
C Chis
Post by C Chis »
I think the part number you need is 038103638k. this comes up as suitable for the BLS engine. You'd need to do a little bit more research before buying though.
Raph71
Post by Raph71 »
Yes exactly!
I just found on ETKA.
Fixing engine cover 1.9 TDI 105 BLS
03G 103 184 (x5)
03G 103 638 (x1) (also called 038 103 638)
