Just another camper build
paddythecaddy96
Post by paddythecaddy96 »
So I figured it was about time I put a bit more in to the forum rather than just scroll through everyone else’s build.
The missus and I decided that we’d like to do a lil camper for holidaying in around the uk and after helping our friend do his caddy, we decided to get one ourselves. Cue the hours spent trawling though the usual suspects for a van before stumbling across this lil gem at £4500 & 83k miles. snapped up last july the day after finding it.
Re: Just another camper build
Post by stu_b »
Looks and sounds like the start of a new build thread 👍
The Caddy looks to be in good nick so you've got a good start & base to work with
Have you started / completed any mods yet ?
Nicklouse
Post by Nicklouse »
Nice. Looks like we have very similar starting points.
paddythecaddy96
Cheers stu. Yeah, the windows are in, sound deadening, insulation, carpeting all done. Still lots to do! Image
Will post more as I go through the gallery of what I have!
paddythecaddy96
That a pretty beefy roof rack you have on yours nick! If your getting rid of it let me know!
paddythecaddy96
As with pretty much all the builds, it all started with a good clean and taking out things that I didn’t think I’d need (and thankfully keeping things I thought were unnecessary!) so went from this Image
To this Image
And then this Image
In the few days last summer where I wasn’t a pool of sweat after work.
Nicklouse
Post by Nicklouse »
paddythecaddy96 wrote: Tue Apr 25, 2023 9:18 pm That a pretty beefy roof rack you have on yours nick! If your getting rid of it let me know!
Keep an eye on my build when it gets started as I think it will be too much for me as I will be dailying it. So might switch to roof bars.
paddythecaddy96
After all the cleaning down which thankfully wasn’t much it was pretty clean as far as vans go! Then we went about the sound deadening and insulating, which with the 30 degrees heat last summer meant the adhesive on the back went on like a treat.
We went with the dodo Matt stuff for all the insulation bits, and on the floor (didn’t get any photos) we used the dodo duo roll which was well easy to put down, then put a sheet of 12mm ply, followed by some amtico
paddythecaddy96
In between the deadening and carpeting, got the windows in. Due to the lack of balls on my side, got my friend to cut out the bits on the door, but then managed to do the rest and was pretty proud of them!Image
Post by stu_b »
Coming along mate
Looks like u did a good job on the windows
Bet your happy with the result
paddythecaddy96
Cheers Stu, went a lot better than I was expecting!
paddythecaddy96
Got a few free moments over the bank holiday, so got most of the panelling on the ceiling done, hoping to get the electrics all wired up on Wednesday and then get started on building some shelves and a bed!
paddythecaddy96
Haven’t got round to the electrics unfortunately because of the weather (as always Image) but on the plus side got this bad boy
paddythecaddy96
Was good to have a weekend off doing bits and pieces to the van. Spent a few minutes on Saturday trying to sort out the drivers sun visor clip. I’d ordered a cheap, cheerful knock off one to replace it and shock horror it broke at the first use. Image
Also got a bit of time time in between downpours to do a bit of spraying, and thought I did an alright job for my first time
3rdLeg
Post by 3rdLeg »
Mate we could get those wheels looking way better if you can be arsed?! Need to spend more time on the prep 👍
