Aussie work Van
MWMRacing
Aussie work Van
Post by MWMRacing »
We have had a SWB Caddy Runner with the powerhouse 1.2 litre turbo petrol for the last 5 years, we have used it as a work van carrying everything from IT infrastructure to Engines and gearboxes for our racecars.
The time has been coming for a while that we wanted another work caddy, but wanted one a bit more practical for us- so in came the idea of a TFSI swapped Caddy to get a touch more grunt- ans wanting a Long wheel base.
So we set about the research, talking with several people who have already done much the same swap- researching basic theories on wiring and soon discovering it is actually a rabbithole, and what will go into the diesel to petrol swap.
We have located a 2010 Diesel Caddy Manual with a blown diesel- which we will be picking up shortly- this will be our donor for the swap- theory being that given this will take some time that we dont want to take our existing caddy off the road.
Now- the engine/gearbox/wiring donor- we dug into potential donors and the costs associated and we settled on getting an EOS or Jetta as they usually havent been ragged on as much as a GTi- after perusing for some time we found an EOS donor at the salvage auctions that was in pretty reasonable condition.
BWA TFSI- DSG- and being a 2008 we arent too far apart on the year of the Caddy and Eos so that should Image minimise the incompatibilities during the swap Module wise.
First step is getting the EOS drivable so we can test to ensure there isnt anything reliability wise we need to sort before the swap- and we are also organising a list of parts we will replace as precautionary repairs.
Next is something we are beginning to work on immediately, developing our comparison tables for the ECU pinouts to know what we need to put where during the splicing.ImageImageImage
Sent from my SM-S916B using Tapatalk
2013 Caddy Runner- 66KW manual- 2005 SWB Converted to TFSI DSG in house - Quite proud of this :D
itease
Re: Aussie work Van
Post by itease »
Good to see you posting on here mate and looking forward to seeing the progress of your Caddy. Hit me up if you need any help with the conversion.
Cheers,
Mark
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
itease wrote: Tue Jun 06, 2023 4:41 am Good to see you posting on here mate and looking forward to seeing the progress of your Caddy. Hit me up if you need any help with the conversion.
Cheers,
Mark
Thanks Legend, i certainly will- already appreciate the assistance thus far!
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Well, progress ran to a halt for a short period as i finished my university courses, but back onto it now- we have the caddy itself now, were told it was a long wheel base before we picked it up but it turns out its a short wheel base, but alas full steam ahead.
Unfortunately, it is wrapped and its in terrible condition, but its protected the paintwork underneath so it will be slow progress but it will tidy up, thus far we are 3 hours in with only the side door and rear quarter mostly stripped.
Wiring conversion diagrams are currently in progress and are about half done as well, so just working on getting the EOS running properly to scan and test drive to ensure we dont have any issues, then we will start the swap.Image
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
More progress on the conversion, finally getting it on the move now- took the old diesel engine out last weekend- and spent this weekend installing some GTI seats ive had stashed away for some time from my daily driven GTI after i upgraded it.
Next weekend we are putting the donor EOS onto the hoist to start pulling the TFSI out, giving it a timing belt and DSG service whilst out and get it installed into its new home- then starts the most time consuming part- the wiring.ImageImageImage
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Now we are into the slow progress area- been spending hours developing conversion diagrams for the wiring- and have just started the repinning process- got most of it done now and next step will be to chase out the extra wiring in the eos harness that i need that my caddy doesnt currently have.
But even before that ill be swapping the subframes between the two so i can get the EOS off the hoist and back out into the yard.
Also picked up a newer style DSG shifter than what came in the EOS- so just have to look into the harness diagrams and see if i can hopefully make it work Image
Hopefully will have some more in depth progress shortly with some of the more fun stuff once we move the subframe across as we have some goodies like new bushes ImageImageImageImage
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Also forgot- old gearbox mount in the eos was buggered so grabbed a new one and popped it in before we got started on the wiring harness- piccies show the difference between the caddy manual diesel one and the eos TFSI DSG mount ImageImageImage
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
More progress today, been a few weeks in-between but slowly making more progress.
Today's effort was the removal of both exhausts, and the swapping of subframes, shocks, brakes, uprights, and control arms between the EOS and the Caddy.
I reinstalled the Caddy subframe into the EOS to keep it rolling so we could move it about, and get it off the hoist to a place I can strip it further.
Swap went well, kept the alloy control arms out of the EOS on the floor so I can swap the bushes over with brand new Whiteline Poly Bushes so it's all pristine as it goes back together and handles like a new car once back in the caddy. The brakes will get looked at with replacement consumables and the shocks will as well, but to start with this is ideal as it will allow us to just move the car around once the engines back in.
Next up is the stripping of both interiors so I can chase the DSG harness through the EOS to the gearbox itself, and then transfer it to the Caddy to the modern style shifter- also tossing about the idea of moving the EOS climate control to the caddy whilst I'm in there, but still undecided on this as I really want to get the Caddy running first.
I also have to pull the interior to get to the EOS Fuel Pump in case i have to do a frankenpump for the diesel tank- but keeping my eyes peeled for a petrol Caddy fuel tank, lines etc to keep it beautifully neat, rather than doing the dodge method.
Re: Aussie work Van
Post by stu_b »
fwiw, for all the intricate detail your going thru n doing, I would recommend taking an extra bit of time to include the climate air and also the try and get a petrol tank to complete the job 100%
otherwise, if your anything like me or others, you'll wish you had done it while you had the chance and kick yourself for not doing it later down the track
the work to date looks exemplary
it's going to be a tidy vehicle when completed
snuffegull
Re: Aussie work Van
Post by snuffegull »
I'm gonna follow this for sure! Nice progress so far :D
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
stu_b wrote:fwiw, for all the intricate detail your going thru n doing, I would recommend taking an extra bit of time to include the climate air and also the try and get a petrol tank to complete the job 100%
Yeah it's one of those things, given everything is going to be out, the ammount of wiring ive got to do anyway, it's not as though its a large conversion to do the climate in comparison to putting the engine and DSG in, and the harness is already going to be unwrapped so may as well- all comes down to time I suppose haha
Ill keep my eyes peeled for the tank, as it's also the simplest method for the tank side of things as the path of least resistance.
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
snuffegull wrote: Sun Apr 21, 2024 8:06 pm I'm gonna follow this for sure! Nice progress so far :D
Appreciate it- hope i do it justice- like all the vans i think it will perpetually be a work in progress even once its running- still have goals of some of the goodies i see in other vans like Axle Flip kits, Coilovers, maybe a K04 swap down the track, some 6R brakes.
We do a fair bit of racing, and there's a rally sprint i would really LOVE to take the caddy to just to see the reactions of a caddy going full tilt :lol:
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Unfortunately ive been sick all week so only got a few hours to work on the van this week.
I got to replacing the bushes on the EOS Control arms- the inners went in beautifully, but I soon discovered that the kit I ordered from Whiteline for the rear control arm bushes were caster correction bushes, so they werent matched- so instead of installing something that didn't fit out use case I went fishing in the race spares (we have a Golf 6R racecar) and fished out some good used bushes from the spares kit which should do till I get replacements down the track.
Once replaced I popped them back into the van and spent some time reassembling the suspension so if I need to roll it to the hoist it can now be dropped on the floor and moved sucessfully.
I also spent some time doing some interior stripping and dropping the heat shields to replace the shifter- and got the new style DSG shifter installed successfully- which has also given additional room for the wiring that needs to take place in the interior anyway.
I also spent a bit of time stripping the steering wheel, MFSW module and blinker stalks out of the eos to pop in the caddy, a lot of it was unfortunately missing when I got it, so that should resolve that as an issue as well which is great- I'm keeping my eyes peeled for a cheap MK5 or MK6 GTI wheel with the flappy paddles, which ill install at a later date- anyone know which MFSW module I'll need for that?
Ill probably also spend a bit of time doing some cleaning of subframe components over the next little while just to tidy everything so it looks near new before I put the engine back in.
I have to do some more stripping of the eos interior as my next port of call for chasing the wiring out that I'm after as well, I just didn't quite have the time today unfortunately.ImageImageImageImageImageImageImageImage
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
More progress this weekend- less so than normal but the dashes were probably the most obnoxious dashes I've ever had to remove from cars and ive done a few over time...
So I spent some time removing the caddy dash on Saturday, so I could get access to the full loom so I can add the required wiring- but I think ill have to take a bit more out so I can get to everything. I also removed an aftermarket phone kit from it that is well and truly dated, as ill likely just replace the head unit with a carplay model with integrated mic and Bluetooth etc for an OEM style look.
I also went out to the EOS now its off the hoist and did the same, unfortunately it was raining fairly heavily so that was a miserable time removing it but I got everything out thankfully and can now start removing some more of the bits and pieces a bit deeper but will go about labelling some of what I have there already for future reference if I need any of it (thinking might need some additional wiring for the steering wheel setup and the dash cluster potentially)
I also spent a bit of time test fitting the eos cluster onto the caddy before disassembly- ended up just taking the face off both clusters and switching them over, but I think ill have to come up with something to get the trip meter button and the time and date buttons working, maybe a 3D print of the cluster segment or potentially some aftermarket buttons elsewhere soldered onto the PCB of the dash- plus some grommets to plug the existing holes.
Next up is diving further into the EOS wiring to chase out what I need, which I thought I might of gotten to this weekend, but the dashes took me longer than anticipated especially given I had to have the EOS doors shut whilst disassembling so I didn't get drenched ImageImageImageImageImageImage
snuffegull
Re: Aussie work Van
Nice progress!
I actually dont mind these dashes, way nicer to work on than many other vag models
